Necessary to resize rods after changing bolts?
How important is it to resize your rods when you install new rod bolts?
I'm asking because some people are telling me that I'll risk spinning a bearing if I don't get them resized. Keep in mind, these are cap-screw bolts, not the kind that need to get pressed in/out.
The last thing I feel like doing right now is removing the rods and paying to get them resized. All I'm planning on doing is popping the pan off and replacing the current bolts with new ones.
Re: Necessary to resize rods after changing bolts? (EnzoSpeed)
Should not be any problem.You ended up buying Crower replacement bolts right (same as whats in there).
Glenn
Glenn
TheSwift1
10-21-2003 11:41 AM
