CEL misfire code.....
Old Sep 22, 2005 | 09:28 AM
spoolin_si's Avatar
Default CEL misfire code.....
greddy turbo on my 00 Si keep getting that code...i have reset it several times but it keeps coming back. Im running the greddy blue box and 7 heat range plugs.
any ideas guys??
Old Sep 22, 2005 | 10:39 AM
beepy's Avatar
Default Re: CEL misfire code..... (spoolin_si)
Any other codes? Generally isfire codes come from other problems that may themselves throw codes. If not, you may just need to tighten the gap some.
Old Sep 22, 2005 | 01:23 PM
notoriousB's Avatar
Default Re: CEL misfire code..... (beepy)
or it could be worse - ringland failure will throw misfire codes, I know first hand.
what is the plug gap you're running? you might want to do a quick compression test just to check the general condition of each cylinder.
Old Sep 22, 2005 | 02:03 PM
FredoSP's Avatar
Default Re: CEL misfire code..... (notoriousB)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by notoriousB &raquo;</TD></TR><TR><TD CLASS="quote">or it could be worse - ringland failure will throw misfire codes, I know first hand.
100% correct, and I had the 18g kit back in 2002
BI8B
10
Mar 27, 2006 10:48 AM
TurboTurtleGSR
Jul 2, 2003 03:14 PM
guyuenvy
Feb 11, 2002 09:32 AM
sagaprelude
Aug 3, 2001 12:00 PM
