HKS SSQ bov is causing a surge!
Old Sep 22, 2005 | 06:26 PM
ham's Avatar
ham
Default HKS SSQ bov is causing a surge!
When i hit full boost, the bov makes a nice chirp sound... which is good.
If i get little amount (1-6psi), i hear a compressor surge sound. people say this sound is the bov and thats the sound it makes with lower boost.
BUT my compressor is facing the driver side and the bov is facing the pass side and i hear the surge on the driver side, so its the air coming back out the turbo.
any thing i can do to this thing?
Old Sep 22, 2005 | 06:27 PM
ham's Avatar
ham
Default Re: HKS SSQ bov is causing a surge! (ham)
note: i have my main vacuum port on the intake mani going straight to the bov
Old Sep 22, 2005 | 06:55 PM
vaporboy12's Avatar
its got a adjustment screw on it try mess with that till its right sound like it need to be a bit more lose
Old Sep 22, 2005 | 09:26 PM
1turbodc2's Avatar
no it dosen't hks is not adjustable and mine makes the same noise it sounds like it sputters nad then fires off...
Old Sep 23, 2005 | 01:56 AM
swlabhot's Avatar
The old HKS is adjustable but I wouldnt play with that. The stuttering sound at low boost is normal... I have that too and alot of other people running SSQV also have the same sound. I wouldnt worry about it.
Old Sep 23, 2005 | 02:08 AM
NrG's Avatar
NrG
Default Re: HKS SSQ bov is causing a surge! (swlabhot)
1-5psi, my ssqv would make a surge sound too. but sometimes it's the bov under low boost. it's a dual stage bov. not too sure about the ssq.
small surge isn't a problem.
Old Sep 23, 2005 | 03:27 AM
ham's Avatar
ham
Default Re: HKS SSQ bov is causing a surge! (NrG)
i dont like it!
Old Sep 23, 2005 | 05:35 AM
Finest's Avatar
That's how it's supposed to sound like. Most "high psi" BOV's don't open up at low boost levels, and the low-mid range BOVs can't hold over 15psi. The HKS works both ways because of the sequential valving system. If you don't like it, you can always get a different BOV.
Old Sep 23, 2005 | 08:07 AM
msmotorsports's Avatar
If the valve is working properly under high boost conditions but not at low boost conditions then the spring is too stiff for the vaccum your motor uses. Take a vaccum gauge at idle with the car completely warmed up. Once you get that value you can then choose the correct HKS spring for your application.
Old Sep 23, 2005 | 08:40 AM
mrbsponge's Avatar
my blitz ssq does the same thing, it has 2 different sounds from low boost and high boost.
im pretty sure the ssq are supposed to sound like this
Old Sep 23, 2005 | 09:03 AM
theEGkid's Avatar
One of my Customers actually was wondering the same thing. I backed off the adjustment bold a hair and everything works fine.It does sound diffrent tho at low boost. Just the way its designed
Old Sep 23, 2005 | 05:04 PM
ham's Avatar
ham
Default Re: (SmoothlilHatch)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SmoothlilHatch &raquo;</TD></TR><TR><TD CLASS="quote">One of my Customers actually was wondering the same thing. I backed off the adjustment bold a hair and everything works fine.It does sound diffrent tho at low boost. Just the way its designed</TD></TR></TABLE>
i dont think i have any adjustment. there is a little hole on top, i dont know if thats for an adjustment screw?
Old Sep 23, 2005 | 05:31 PM
non-VTEC's Avatar
Default Re: (ham)
the newer HKS blow off valves dont have the adjustment bolt anymore. they probably got tired of people messing with it because of this reason.
i would say its normal. my HKS does the exact same thing......
Old Sep 23, 2005 | 06:58 PM
JDM EJ1 95's Avatar
my greddy type S had a small surge right before it went off at low boost...
i doubt its the same idea but
inside the greddy there are 2 springs.. a stiff one and a small one inside the stiff one...
i opened it up and took out the stiff one...
works like a charm now
Old Sep 24, 2005 | 06:20 AM
rhd's Avatar
rhd
Default Re: (JDM EJ1 95)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JDM EJ1 95 &raquo;</TD></TR><TR><TD CLASS="quote">my greddy type S had a small surge right before it went off at low boost...
works like a charm now</TD></TR></TABLE>
neither of my Type s's had 2 springs?
Old Sep 24, 2005 | 08:05 AM
JDM EJ1 95's Avatar
mine did!
lol theres a outter stiff one and an inner weaker one...
i think mine is the high boost type S
Old Sep 24, 2005 | 08:13 AM
rhd's Avatar
rhd
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JDM EJ1 95 &raquo;</TD></TR><TR><TD CLASS="quote">mine did!
i think mine is the high boost type S</TD></TR></TABLE>
high boost type S? i thought there were only the type S and the type R?
i'll check another one....since 2 of them were used, i have 3 or 4 around here somewhere
yeah_its_boosted
Sep 14, 2006 12:15 PM
VI Boost
Dec 11, 2004 06:59 PM
leadtrum
Jun 12, 2002 04:07 PM
turbogsr13z
Apr 7, 2002 09:32 PM
