First boosted gsr
Old Sep 22, 2005 | 07:55 AM
silver88crxsi's Avatar
Default First boosted gsr
hey as it says this would be my first boosted setup. I have been searching and not really finding what i need. Is going on a stock motor and i was thinking a full race kit or rev hard. Its goin to be a daily drive and i want atleast 300 at the wheels. Also what managment system would work best , injector size, and gagues needed. Thanks
Old Sep 22, 2005 | 10:14 AM
Default Re: First boosted gsr (silver88crxsi)
Alright outa 43 people who have looked at this post there had to have been some1 who could have helped. Thanks. Oh well can atleast one person tell me some good sites to look at so i can try to find answers myself since no one else seems to wanna help. I mean i thought that is what this site was for is help. . . . .
Old Sep 22, 2005 | 10:31 AM
bennyhonda7's Avatar
k first of all dont do afc hack or fmu convert to obd1 if necessary and run uberdata...info at pgmfi.org get stock dsm 450 cc injectors with resistors(available at radioshak) injectors get off of junkyard eagle talon turbo, eclipse turbo, laser turbo....obd1 ecu has to be chipped....you can run p06 chipped for vtec, stock gsr chipped available at http://www.xenocron.com, p28 chipped etc as long as it is vtec and obd1 it will run any motor with the correct map burned to chip...I advise also in getting an eprom burner...off ebay the willem burner is what i use...c2956 chips available at http://www.xenocron.com...you will eventually want a wideband like a plx300 or at the least a basic aft gauge and have someone wideband tune you...(it will save your motor) basemap is not good for everyday driving.... http://www.homemadeturbo.com has lots of turbo info....and fuel management info especially uberdata,crome,turboedit....HONDATA SUCKS! run something like a t3/4 60/63,14b or anything bigger than 14b 16g is nice....t3 off volve 42.48 is too small for that motor....look at turbo compressor maps for good choices...your large 57trim/60 t3 will be excellent...or spend a lot of cash on a garrett gt series...thats pretty much it for over 300 look at rods anything under 280 id say your stock rods are descent with conservative tune....nothing above 12-15psi....
Old Sep 22, 2005 | 10:35 AM
Dunc's Avatar
BCICAN
I'll try and help then. Just save yourself the money down the road and go with the full-race kit instead of the revhard. Revhard is more for newbies who want 250 and that's that. Boost is addicting, and I bet 90% of the people on here will agree with that. 7psi is cool, then 12 is awesome, but soon 20 is what you are wanting and you won't be sure that 20 will keep you happy. All in all, just go with the fullrace and save yourself some headache.
Management is up to you but get something such as uberdata, hondata, crome, neptune, AEM, autronic.....there are alot of possibilities so do some research and figure out which one best suits your needs. Don't let people on here tell you which one is best and other BS. Learn and decide for yourself.
Gauges boost, EGT, Oil pressure, A/F (wideband though), water temp are the main ones. Once you have those get others that you want. For the A/F, buy a real wideband and not the Autometer A/F gauge...that one is just worthless to you.
Injectors You pick the whp you want and choose a cooresponding size, but keep in mind that boost is addicting.
310cc 200~220whp
370cc 220~280whp
440cc 280~330whp
550cc 330whp~380whp
660cc 380whp~425whp
720cc 425whp~475whp
880cc 475whp~525whp
980cc 525whp~600whp
Credit where it is due: You should thank Jeff Evans for those numbers.
Hope that helps a little. Oh and remember no matter what route you go...GET IT TUNED!
Old Sep 22, 2005 | 11:07 AM
Default Re: First boosted gsr (Dunc)
Finally some good people in the world. Thanks for the info guys
stock ek
May 15, 2007 02:31 PM
tspkenneth
Feb 20, 2005 07:15 AM
EK FLY
Oct 2, 2004 04:33 PM
sharkey65a
Mar 19, 2003 11:09 PM
Drag III Integra
Jan 26, 2002 10:13 AM
