Eg wire harness?
Old Sep 25, 2005 | 10:05 AM
Hyaboosta's Avatar
Default Eg wire harness?
We just finished swapping my freinds Eg that previously had an LS vtec and now we put a b16a. when we wired it up everything cranks fine the warning lights on the cluster work but the tach, spedo and fuel do not move. the radio also does not have power. We have one connector that we could not find the connection to. Does anyone know what this connector goes to?
thanks for the help
Old Sep 25, 2005 | 11:16 AM
Laserjock's Avatar
Default Re: Eg wire harness? (Hyaboosta)
First, re-size the pics cus I couldn't even find the reply button
Is the engine running? I remember having a problem with a JDM B18C1 connector that was interchangeable with another (same number of pins, same connector size) that had to be extended to reach the connector to the passenger side of the engine compartment. The first symptoms was no fuel in startup cause the pump was not getting power.
Bear in mind this was 5 years ago so the info is kinda fuzzy...
Old Sep 25, 2005 | 03:51 PM
eg crunkmonster's Avatar
Default Re: Eg wire harness? (Laserjock)
i think thats a crank position sensor plug, u do not need it for obdI, i just left it hanging in my car. what year is the harness? i know if u use a newer integra harness like 99-01, the wire for the tach signal is not the same
Dez_WithTheEG
Nov 4, 2013 06:29 AM
BrianFreels
Jun 5, 2009 09:40 AM
ClikHonda
Jul 3, 2008 07:48 AM
Hyaboosta
Sep 29, 2005 05:27 PM
spl_civic
14
May 5, 2003 12:16 PM
