no vacuum at idle
Old Mar 30, 2006 | 09:13 PM
Quickgti1.8t's Avatar
Default no vacuum at idle
I have a friend with a gen 2 RX-7 on standalone that he just put in. He tells me he has no vacuum, he pulled a vacuum line and it blew air not sucked air..... He has had a few people who sell the standalone to look everything over and they can't find the problem. The car idles like ****, barely revs etc....
I heard someone say a faulty wastegate(he has a tial 38mm) is the cause it can be open a little and causing problems??? what do you think? He doesn't even have the vacuum line hooked up to it
Old Mar 31, 2006 | 08:51 AM
Civicman86's Avatar
Umm something doesnt make sense about any of that. A motor is just a vacuum. So unless you have a turbo creating pressure or blowing air in, then it should always be sucking in air.
A motor blowing air out instead of creating a vaccum defeats the whole purpose of internal combustion motors.
Old Mar 31, 2006 | 09:01 AM
JDMB20TDA's Avatar
Default Re: (Civicman86)
yea what?
no vaccum... that doesnt make anysense the motor can be pushing air out of a vaccum line... if the engine is pulling in anyamount of air through the manifold with the throttle plate closed there is a vac... and if there was alarge enough vac leak the vehicle would just rev to death
Old Mar 31, 2006 | 07:51 PM
Default Re: (JDMB20TDA)
beats me, now he tells me he has 4 in oh vac. im going to kick his ***. i think its just his tuning
Old Mar 31, 2006 | 08:21 PM
StolenTeg's Avatar
Default Re: (Quickgti1.8t)
Tuning has nothing to do with your vacuum being higher or lower
Old Mar 31, 2006 | 08:49 PM
Default Re: (StolenTeg)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by StolenTeg &raquo;</TD></TR><TR><TD CLASS="quote">Tuning has nothing to do with your vacuum being higher or lower</TD></TR></TABLE>
your telling me an a/f ratio of 9:1 vs a a/f of 14.7:1 will idle the same. I know my car idles like crap when its too rich at idle
Old Mar 31, 2006 | 09:19 PM
Sketch_hs's Avatar
too rich/lean AFR will cause poor idle and low vacuum. FACT
The motor has to be pulling some vacuum to run
Old Mar 31, 2006 | 09:31 PM
B18C1CYA's Avatar
Default Re: no vacuum at idle (Quickgti1.8t)
the gauge is probly installed wrong
Old Apr 1, 2006 | 06:18 PM
Laserjock's Avatar
So besides pulling the vaccuum line, does he have a boost gauge (I hope if he spent all that money on a standalone - he does) to see what the actual vaccum reading is?
I second a vaccuum leak. My friend had one and asked me to check out his Touring model for a rougher than normal idle. Vaccuum line slipped.
daymkimchee
Honda S2000
Mar 25, 2010 08:36 AM
98ludesh17
Apr 20, 2007 02:40 PM
joethejoeman
Oct 13, 2006 05:08 PM
AnAccordIsForever
Jul 11, 2006 07:04 PM
DaX
Jun 4, 2004 09:19 AM
