pump gas limits?
Old Mar 30, 2006 | 12:03 AM
budget's Avatar
Default pump gas limits?
whats the max whp # that can be pushed on 93 octane safely? did a search and the #'s keep going up
Old Mar 30, 2006 | 12:23 AM
Fenrir51's Avatar
Default Re: pump gas limits? (opendp)
Too many variables to make an accurate number. Slap on some WI and you probably wouldnt have to worry about anything
Old Mar 30, 2006 | 12:38 AM
D@nnY's Avatar
Default Re: pump gas limits? (Fenrir51)
generally safe is 100 hp per cylinder which in our cars is 400
a little higher If you back down timing
Old Mar 30, 2006 | 09:18 AM
budget's Avatar
Default Re: pump gas limits? (D@nnY)
Old Mar 30, 2006 | 09:32 AM
RICE POLICE SIP's Avatar
Not sure on HP ratings but boost wise I believe it's roughly 12 lbs...
Old Mar 30, 2006 | 10:08 AM
StolenTeg's Avatar
Default Re: pump gas limits? (Split Image Prez)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Split Image Prez &raquo;</TD></TR><TR><TD CLASS="quote">Not sure on HP ratings but boost wise I believe it's roughly 12 lbs...</TD></TR></TABLE>
12lbs aint much at all, im running 16 psi on 93 right now with more room to spare.
Old Mar 30, 2006 | 10:10 AM
Turbo-charged's Avatar
Default Re: pump gas limits? (StolenTeg)
i ran 25psi on pump gas for over a year
Old Mar 30, 2006 | 10:18 AM
nonvtecD's Avatar
haha, what?!?! It has to do with cylinder pressure too. I'm under the impression because of the smaller bore of the D series the pressure on the piston is a lot higher than a bigger bore but still 1.6 liter B series. 400 or maybe a little more sounds about right to me though.
Old Mar 30, 2006 | 10:23 AM
chubz0r's Avatar
Default Re: pump gas limits? (nonvtecD)
from what ive seen around here, its usually around 400-450 on pump gas. i was always wondering what determines the actual limits though.
Old Mar 30, 2006 | 10:28 AM
nonvtecD's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by D@nnY &raquo;</TD></TR><TR><TD CLASS="quote">generally safe is 100 hp per cylinder which in our cars is 400
a little higher If you back down timing </TD></TR></TABLE>
It's not related to cylinders because not all cylinders are the same size
Old Mar 30, 2006 | 12:05 PM
JDM00SI's Avatar
I usually see 16-18 lbs of boost max on pump...
I have a buddy that makes like 515whp on pump.....
Its alot of timing to make that much power on pump...
more timing= less reliable.
The good tuners take out timing while adding boost, at least you know its reliable
Old Mar 30, 2006 | 12:06 PM
turbosi03's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by nonvtecD &raquo;</TD></TR><TR><TD CLASS="quote">
It's not related to cylinders because not all cylinders are the same size </TD></TR></TABLE>
difference in cylinder size is not that significant because we're talking about the stress placed on a cylinder from a given power output level.
The more important factor is the "room for error" you are left with when dealing with 100+hp per cylinder. which isn't much at that level...
Old Mar 30, 2006 | 12:13 PM
turbosi03's Avatar
Default Re: pump gas limits? (JDM00SI)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JDM00SI &raquo;</TD></TR><TR><TD CLASS="quote">I usually see 16-18 lbs of boost max on pump...
The good tuners take out timing while adding boost, at least you know its reliable</TD></TR></TABLE>
Your talking about methods to try to prevent detonation. but with little room for error all the timming tricks in the world wont save a motor from a bad tank of gas or some minor thing going wrong that causes a big mess...
keep in mind boost level is completely irrelevant. It's the power levels that determine the amount of stress a motor sees...
Since we are talking about reliability, people need to think more about heat management... for that is the #1 killer of reliability! (assuming a good tune)
Old Mar 30, 2006 | 12:48 PM
onefstek's Avatar
I have ran 25 psi on 92 octane and made 550 whp. 9.5:1 cr gsr.
Old Mar 30, 2006 | 01:08 PM
turbosi03's Avatar
Default Re: (onefstek)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by onefstek &raquo;</TD></TR><TR><TD CLASS="quote">I have ran 25 psi on 92 octane and made 550 whp. 9.5:1 cr gsr. </TD></TR></TABLE>
Thats cool, but for how long? and why do you talk in past tense?
lets not omit the word "safely" the original poster used...
Old Mar 30, 2006 | 01:51 PM
onefstek's Avatar
Default Re: (turbosi03)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by turbosi03 &raquo;</TD></TR><TR><TD CLASS="quote">
lets not omit the word "safely" the original poster used...</TD></TR></TABLE>
Daily driver for the last two years, and still going strong.
I drag race on the weekends, best time 10.7@135mph
Featured in the April 2006 issue of Import Tuner, white 2000 civic h/b page 68, I think
Old Mar 30, 2006 | 01:56 PM
budget's Avatar
besides "onefstek" who else that makes more than 400whp daily drive,(to work/school and everything else. not to just go grab a burger) there car on 93?
Old Mar 30, 2006 | 03:03 PM
Soccerking3000's Avatar
Default Re: (opendp)
i do, but we have 100 at the pump here so its not exactly the usual "pump gas"
Old Mar 30, 2006 | 04:00 PM
nonvtecD's Avatar
Default Re: pump gas limits? (turbosi03)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by turbosi03 &raquo;</TD></TR><TR><TD CLASS="quote">difference in cylinder size is not that significant because we're talking about the stress placed on a cylinder from a given power output level.
The more important factor is the "room for error" you are left with when dealing with 100+hp per cylinder. which isn't much at that level... </TD></TR></TABLE>
huh? How is cylinder and bore size not a signicant factor? Yes it is. I'm betting an H22 is safer at 400 hp than a D series is.
Old Mar 30, 2006 | 04:02 PM
BOOSTEDS2K's Avatar
Default Re: (Soccerking3000)
I ran 18psi on a stock s2000 motor for almost a year and made 450whp on 93 pump gas only reason I got rid of it was because I did a fully built motor that only runs on c-16. how dumb of a move was that
Old Mar 30, 2006 | 04:10 PM
infrontofu's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by turbosi03 &raquo;</TD></TR><TR><TD CLASS="quote"> Since we are talking about reliability, people need to think more about heat management... for that is the #1 killer of reliability! (assuming a good tune)</TD></TR></TABLE>
How would you go about this heat management???
Tony the Tiger's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by opendp &raquo;</TD></TR><TR><TD CLASS="quote">
Depends on compression ratio and how much HP/L (or TQ/L). The lower you go, the more power you can make at a lower octane rating but with sacrifices of having a sluggish low CR engine.
200-220HP/L seems like a good reference point IMO for 93 oct on a Honda B-series on factory compression (10.0:1 or so).
Modified by Tony the Tiger at 9:40 PM 3/30/2006
99_GS-T's Avatar
It's not a Honda, but I was in the neighborhood of 400 WHP on 91 octane in my stock block DSM.
On advantage of pump gas is that it seems to burn extremely quick. Running low timing advance doesn't really make the EGTs go all that high if you have a good setup. The key to high pumpgas power is keeping PEAK cylinder pressures down and the easiest way to do that is drop the timing advance down.
To make up for the lost power from the lower timing, you up the boost. I know guys doing over 30 PSI on 91 octane. I never bothered to go much higher then 25 PSI on the GT2871R and on the T67, I was scared the bottom end was going to let go above 20 PSI, racegas or pumpgas.
Old Mar 30, 2006 | 04:55 PM
turbosi03's Avatar
Default Re: (99_GS-T)
huh? How is cylinder and bore size not a signicant factor? Yes it is. I'm betting an H22 is safer at 400 hp than a D series is.</TD></TR></TABLE>
I'm betting the bore size is not the only difference between an H-series and a D-series motors
when talking about stress on parts from the explosions inside a cylinder, the bore size isn't much of a factor compared to the strength of components, cyl wall thickness and material, etc... and of course the tune.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by infrontofu &raquo;</TD></TR><TR><TD CLASS="quote">
How would you go about this heat management???</TD></TR></TABLE>
by making sure you have a sufficient cooling system. you may see people with 600+hp using stock radiator's etc... but that's because they are simply trying to get down the 1/4mi track as fast as they can. street cars need to pay more attention to the cooling system if they are interested in reliability.
also fight the battle with heat soak... such as thermal coating parts, heat wrap, vented hoods or custom air duck's to move air through the eng bay
you can find tons of good treads that discuss this topic
Old Mar 30, 2006 | 05:12 PM
95GSRTT
Guest
Posts: n/a
Default Re: pump gas limits? (Tony the Tiger)
tony is that 120 hp/ liter? Or does the L stand for something else? That just sounds extremely low to me
