help with turbo size...
Old Mar 31, 2006 | 09:01 AM
eg92b16a2's Avatar
Default help with turbo size...
Just looking for what trim and a/r should I be
getting for a
B18C stock block
B16 port and polish head
Portflow springs & retainers
Skunk2 stage 2 cams
flat valves
Was planning to go all motor but ran out of funds.
So switching to the dark side.
I am looking at a T3/T04E snail.
Using a Revhard casting manifold.
Tial 38mm wastegate.
Can I still use the cams or should I get rid of them?
The car will be a daily driver.
I was thinking 57 trim stage 3 wheel and 63 a/r.
Does that sound good or there any other suggestions?
I would like to get close to 300whp.
Thanks..
Old Mar 31, 2006 | 09:03 AM
JDMB20TDA's Avatar
Default Re: help with turbo size... (eg92b16a2)
depends on what you want as a goal for you car...
how much money you have got to spend...
when u wnat ur torque curve... ect
make some goals and then people will be able to understand what you are looking to get
Old Mar 31, 2006 | 09:09 AM
KeyserSoze's Avatar
Default Re: help with turbo size... (JDMB20TDA)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JDMB20TDA &raquo;</TD></TR><TR><TD CLASS="quote">depends on what you want as a goal for you car...
make some goals and then people will be able to understand what you are looking to get</TD></TR></TABLE>
Also, what will your cr be??
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by eg92b16a2 &raquo;</TD></TR><TR><TD CLASS="quote">Was planning to go all motor but ran out of funds.
So switching to the dark side.</TD></TR></TABLE>
Welcome to the church.
Old Mar 31, 2006 | 09:18 AM
eg92b16a2's Avatar
Default Re: help with turbo size... (KeyserSoze)
I wanted it for daily driving and sometimes to the 1/4 track.
Not a lot of money so I am getting a T3/T04E.
I am not planning to work on the block for now but maybe later on to compliment my head.
I would like boost to develop at around 3-4k rpms and stay up to 6-8k
Only planning to run 8lbs on low boost and 10-12lbs on high boost.
All this is going into a 94 gsr turtle.
Old Mar 31, 2006 | 09:46 AM
JDMB20TDA's Avatar
.</TD></TR></TABLE>
Well with everything u just said id personally go with the faster spoolin' t3/to4b
its not as efficient for boost over 18lbs but with the amount of boost you are planning on running this turbo would be perfect for you. fast spool, good power
Old Mar 31, 2006 | 10:37 AM
drintegra's Avatar
60 trim or a little bigger t3/60-1 63 AR will give you nice hp with about the same spool as the t3/t4. (depends on AR also)
Old Mar 31, 2006 | 03:21 PM
KeyserSoze's Avatar
Default Re: help with turbo size... (drintegra)
Dont worry about the boost psi, that means nothing really. The amount of boost pressure and the resulting hp level will be different for different turbos. You said earlier that you wanted 300whp, so shoot for a turbo that will give you what you want @ a flow that correlates to the 300hp.
You will be hard pressed to find a turbo that will not produce power so early that you spin the wheels, but will spool as early as 3k rpm. For your app, smaller is prolly better. If you don't have the $$$ for a gt series turbo then try the 50 trim t3/t04 e or b turbos. If you have some extra $$ then go with the gt2871 (with the t3 turbine housing) for sure.
x275radial
Feb 17, 2013 08:56 AM
InTeGrA GsR 321
Jun 21, 2005 03:29 AM
Vtak
Feb 6, 2005 02:25 PM
Spooled1.6L
Apr 11, 2004 11:53 AM
