is this causing my smoke problem??
Old Mar 29, 2006 | 08:18 AM
mraudio13's Avatar
Default is this causing my smoke problem??
Here is a picture
I think that it is too flat to drain?? Help me out i am tired of driving spy hunter!!!
Old Mar 29, 2006 | 08:36 AM
AllmotorEH2's Avatar
maybe try getting a shorter return line so it doesnt have so much slack. Do you have a bigger picture so we can see where the turbo sits to see if it is even possible to get a better angle?
PS i love spy hunter lol
Old Mar 29, 2006 | 09:29 AM
nonvtecD's Avatar
Yeah, we need better pics. Reasons for smoke:
1. Turbo seals 2. Bad return line 3. Too big of a feed line 4. Rings You decide.
Old Mar 29, 2006 | 10:27 AM
mraudio13's Avatar
Default Re: (nonvtecD)
here are a couple more pics, sorry best i could do with the space.
Modified by mraudio13 at 1:46 PM 3/29/2006
Old Mar 29, 2006 | 10:53 AM
chubz0r's Avatar
Default Re: (mraudio13)
best thing i can think of is trying a 45 degree off of the oil pan... i dont know..
good luck though.
Old Mar 29, 2006 | 10:56 AM
mraudio13's Avatar
Default Re: (chubz0r)
I will try that, the wastegate downpipe is the siver one next to turbo. It is making it hard to do that.
Old Mar 29, 2006 | 11:10 AM
br1ev8's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by nonvtecD &raquo;</TD></TR><TR><TD CLASS="quote">Yeah, we need better pics. Reasons for smoke:
1. Turbo seals 2. Bad return line 3. Too big of a feed line 4. Rings You decide.</TD></TR></TABLE>
Add to that #5. not enough crankcase ventilation--&gt;install some sort of crankcase pressure evacuation system. Without it, due to the increased crankcase pressure from a turbo, the pressure will try to escape out of the oil return line, causing oil to leak out of the turbo seals.
Old Mar 29, 2006 | 11:15 AM
mraudio13's Avatar
Default Re: (br1ev8)
1. Turbo seals : Still an avenue I haven't checked (don't want to take off head just yet)
compression check 1:225 2:225 3:225 4:225 leakdown 1:8% 2:8% 3:9% 4:9%
2. Bad return line: is number 1 culpret right now
3. Too big of a feed line: -3an could put in a restrictor??
4. Rings:
5. pcv systrem: current setup line from stock oil can on back of motor (no pcv valve) to catchcan to atmosphere, valve cover outlet to atmosphere.
Old Mar 29, 2006 | 01:19 PM
nonvtecD's Avatar
Yeah, looks like your return is the problem. AN 3 is fine for a feed line. That return is not getting enough gravity. You're going to have to figure out how to get it more vertical, good luck.
Old Mar 29, 2006 | 03:50 PM
T3T495GSR's Avatar
Mine is even worse than that
Old Mar 29, 2006 | 03:56 PM
shortyz21's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by br1ev8 &raquo;</TD></TR><TR><TD CLASS="quote">
Add to that #5. not enough crankcase ventilation--&gt;install some sort of crankcase pressure evacuation system. Without it, due to the increased crankcase pressure from a turbo, the pressure will try to escape out of the oil return line, causing oil to leak out of the turbo seals.</TD></TR></TABLE>
were u born stupid?
Old Mar 29, 2006 | 03:57 PM
ek_chris's Avatar
Default Re: (T3T495GSR)
thats going to be one tough line to figure out. I can't wait to do mine in a week
Old Mar 29, 2006 | 04:48 PM
Flr Power's Avatar
Default Re: (ek_chris)
I say blown turbo seals.
Old Mar 29, 2006 | 05:45 PM
nonvtecD's Avatar
Default Re: (shortyz21)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by shortyz21 &raquo;</TD></TR><TR><TD CLASS="quote">were u born stupid?
Umm, crankcase pressure will do a lot of things, I would know, so... to you
Old Mar 29, 2006 | 06:31 PM
mraudio13's Avatar
Default Re: (Flr Power)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Flr Power &raquo;</TD></TR><TR><TD CLASS="quote">I say blown turbo seals.</TD></TR></TABLE>
Turbo is brand new, I thought that was the problem so i got a new turbo...Matt
Old Mar 29, 2006 | 07:23 PM
splitime's Avatar
Good job looking like an idiot... I can attest to first hand how a sealed pcv system will push oil out the turbo seals.... my rigged catchcan has both VC and PCV system into it... frozen vapor clogged both lines and I was instant Spy Hunter.... cleared them... gone.
A good PCV system is so easily overlooked... and the one mentioned by the thread starter isn't going to be causing his issue.
Old Mar 29, 2006 | 07:32 PM
br1ev8's Avatar
That's it?? Your single contribution to this thread is to call me stupid and then give no reason for making such an accusation....wtf? Whatever, I guess this is what I should expect from the ignorant and uneducated.
Old Mar 30, 2006 | 01:00 PM
mraudio13's Avatar
Default Re: (splitime)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by splitime &raquo;</TD></TR><TR><TD CLASS="quote">I can attest to first hand how a sealed pcv system will push oil out the turbo seals.... my rigged catchcan has both VC and PCV system into it... frozen vapor clogged both lines and I was instant Spy Hunter.... cleared them... gone.
A good PCV system is so easily overlooked... and the one mentioned by the thread starter isn't going to be causing his issue.</TD></TR></TABLE>
So the way I have mine hooked up is ok??
VC to atmosphere
Black box on back of block to catchcan to atmosphere (no pcv valve installed)
Old Mar 30, 2006 | 01:34 PM
wickedEG's Avatar
try putting a 45 degree off of the oil pan and try to make the center section point straight down as best as you can.
Old Mar 30, 2006 | 02:11 PM
sohc_turd's Avatar
Default Re: (wickedEG)
I think the drain is acceptable, ive seen worse. Its got no kinks and its elevated higher than the oil drain bung on the oil pan.
read my findings https://honda-tech.com/zerothread?id=1544369
An easy test that i did was pull valve cover and rear PCV valve and take it out for a little drive and see what happens. if the smoke clears than you know what is causing your smoke screen issues.
Old Mar 30, 2006 | 03:53 PM
booja's Avatar
my return looks very similar to that...
and my car smokes only when i come to a stop after a hard pull or revs constant at 3000+ (freeway)
but when i start moving or revving it stops
Old Mar 30, 2006 | 04:29 PM
Spec R's Avatar
Default Re: (booja)
with a lowered car, that flat surface of the front of the oilpan isnt exactly perpindicular to the ground as it is...its actually sloped against the desired flow.
pokmijn
Mar 3, 2009 02:13 PM
Boosted_Coupe
May 20, 2007 12:15 PM
ek9child
Jan 9, 2006 06:22 PM
Sketch_hs
Dec 22, 2005 01:44 AM
QWKVTEC
Apr 19, 2004 08:45 AM
