how to hook up turbonatics deltagate?
hello everybody.
this is the firs time i'm installing a external wg on my car.
it has two fittings on it.... one at the top and the other is in the bottom.
the top one says vacum and the lower says boost.
i hooked up the upper (vac) fitting to the intake manifold.
and the lower to the fitting on the compressor housing.
is that ok?
thanks
p.s:
i'm not using any boost controller.
is that ok?
thanks
p.s:
Re: how to hook up turbonatics deltagate? (RACEPAK)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by RACEPAK »</TD></TR><TR><TD CLASS="quote">hello everybody.
is that ok?
thanks
p.s:
i'm not using any boost controller.</TD></TR></TABLE>
You've effectively bypassed your wastegate doing it like that If you are only running off the wastegate spring, then hook the vaccum line up to the side port and route it to your intake manifold. Leave the top port that says boost open. That is only used if you are using a boost controller.
is that ok?
thanks
p.s:
wrenchin'
1 Post
Re: how to hook up turbonatics deltagate? (Dunc)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Dunc »</TD></TR><TR><TD CLASS="quote">You've effectively bypassed your wastegate doing it like that If you are only running off the wastegate spring, then hook the vaccum line up to the side port and route it to your intake manifold. Leave the top port that says boost open. That is only used if you are using a boost controller. </TD></TR></TABLE>
yes and no. you only use the top portif you are using an ELECTRONIC boost controller. a manual controller just goes inline with the vac line from the side port to the intake manifold
Re: how to hook up turbonatics deltagate? (I Have an STD)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by I Have an STD »</TD></TR><TR><TD CLASS="quote">
yes and no. you only use the top portif you are using an ELECTRONIC boost controller. a manual controller just goes inline with the vac line from the side port to the intake manifold</TD></TR></TABLE>
You can also use a manual on the top port.
Nextelbuddy
03-26-2004 01:20 PM
boost, controller, crx, delta, deltagate, gate, hook, hooked, instructions, manual, turbo, turbonatics, twin, vac, wastegate
