What size line and fittings for clutch master cylinder to slave cylinder
I am trying to put on my scatter shield and it will not fit with the stock hard line. I figured I will just replace the whole thing with ss line.
Does anyone know what size line and fittings I need.
Thanks
Thanks
Re: What size line and fittings for clutch master cylinder to slave cylinder (underpressure02)
I've made a couple of them and we used 1/8npt on the ends. The line that we use is a -3 and it's about 53? inches long. It's a little longer than needed, but that's what we use.
There was also mention of the thread sizes being M10x1.0, but I haven't tried it to see if they fit any better than what I'm already using.
Re: What size line and fittings for clutch master cylinder to slave cylinder (siblues)
do not use 1/8 npt fittings that is just asking for trouble you need these 592032 592042 earls brake adapters, m10X1.00 to 3an or m10X1.00 to 4an you can get them anywhere tha carries earls.
Re: What size line and fittings for clutch master cylinder to slave cylinder (b18ccivics)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by b18ccivics »</TD></TR><TR><TD CLASS="quote">do not use 1/8 npt fittings that is just asking for trouble you need these 592032 592042 earls brake adapters, m10X1.00 to 3an or m10X1.00 to 4an you can get them anywhere tha carries earls.</TD></TR></TABLE>
Thanks man I will be ordering them from summit tommorw.
i just used 1/8"npt to -3 fittings and i think it was 36" of line. works like a champ
sohcturbo92vx
02-11-2012 01:44 PM
B18EG6
04-09-2003 05:57 AM
