Jus changed manifolds and......
Old Mar 29, 2006 | 02:32 PM
EGinNY's Avatar
Default Jus changed manifolds and......
Okay, theres really no easy way for me to explain this so bare with me......
I just changed my manifold....I had the downpipe redone to fit the new mani.
and a new dump tube made
EDIT: Just installed NEW tial wastegate too....
Now, around 4k rpm's and above i have what "sounds" like a really loud Sputtering exhaust leak..BUT, there is NO leak...
when the car is sitting still and i rev it, its quiet with no leak noise (even past 4k rpm)
Im making full boost and holding it ....If i drive it at low rpm's it seems fine,
Also what i noticed is if i lightly hit the pedal it will make it further then 4k rpm's with out making the noise, but if i give it 1/2 or more throttle it makes the noise....
What could it be.????......
Its not just my wastegate noise cause everything was working fine
b4 i changed the manifold
Sorry if i make no sense but im confused...
Modified by EGinNY at 6:40 PM 3/31/2006
Old Mar 29, 2006 | 02:40 PM
B18 CYA's Avatar
if you changed the mani and downpipe, you need a retune
Old Mar 29, 2006 | 05:42 PM
EGinNY's Avatar
Default Re: (B18 CYA)
bump for some more input
Old Mar 29, 2006 | 05:53 PM
JDM_EM1's Avatar
Default Re: (EGinNY)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by B18 CYA &raquo;</TD></TR><TR><TD CLASS="quote">if you changed the mani and downpipe, you need a retune</TD></TR></TABLE>
samething i was thinkin..
Old Mar 29, 2006 | 06:05 PM
B18 CYA's Avatar
yeah its the only thing I can think of if its sputerring. Probably threw your a/f ratio off and you're either too rich or too lean
Old Mar 29, 2006 | 06:11 PM
drintegra's Avatar
Default Re: Jus changed manifolds and...... (EGinNY)
when you say sputtering due you mean like an exhaust leak or like the car runs different. If the car runs different consider the tune if it does not and the sputtering sounds like a raspy exhaust leak that you only hear when the car has load then answer the following:
Do you have a flex pipe?
Do you have motor mounts?
The leak that you speak of, if it does sound like an exhaust leak may be the downpipe separating from the cat or junction to the exhaust due to the tourque movement which would be easily fixed with a flex pipe or motormounts. If that is not what is wrong then sorry and Im am going to sleep. Good luck
Old Mar 29, 2006 | 06:19 PM
EGinNY's Avatar
Default Re: Jus changed manifolds and...... (drintegra)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by drintegra &raquo;</TD></TR><TR><TD CLASS="quote">when you say sputtering due you mean like an exhaust leak or like the car runs different. If the car runs different consider the tune if it does not and the sputtering sounds like a raspy exhaust leak that you only hear when the car has load then answer the following:
I have flex pipe
I have stock integra mounts
Its not a leak from the exhaust... i just had it reedone from the turbo to the muffler
Could it be a problem with the wastegate.....Kinda sounds like the dumptube, but louder and its a sputtering "sound" the cars not actually sputtering
Old Mar 29, 2006 | 06:48 PM
mrbsponge's Avatar
is it your wastegate you are hearing maybe?
Old Mar 30, 2006 | 05:31 AM
EGinNY's Avatar
Default Re: (mrbsponge)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mrbsponge &raquo;</TD></TR><TR><TD CLASS="quote">is it your wastegate you are hearing maybe?</TD></TR></TABLE>
Its definetly not the wastegate, i was using the same wastegate with the other manifold and this is a MUCH louder/weirder noise...
i posted on another forum n someone said it may be from a small rip in my flex pipe.....dont know...gonna check it later......
Thanks for the input, and any other suggestions/ideas are appreciated.
Old Mar 30, 2006 | 07:07 AM
drintegra's Avatar
CHeck the connection with the dt and the down pipe. Put alittle baby powder on the joints and rev it, if there is a leak you will see it. Other than that I am stumped. GOod luck
Old Mar 30, 2006 | 04:05 PM
corp chronic's Avatar
Bump for my boy....
It kinda sounds like a bad wastegate..
but would a blown wastegate sound like a really
loud exhaust leak?????
Old Mar 30, 2006 | 04:58 PM
Topdawgg's Avatar
dump tube opening at full boost....
haha
Old Mar 30, 2006 | 05:12 PM
92gsrteg's Avatar
def. need a retune everytime u change anything that changed the air flow or similar things. also try puttin new spark plugs in and gap them slightly smaller, my car used to sputter and almost sound like an exhaust leak but it was my ignition cutting out. I have a wideband air/fuel guage and I love it, i can check for things like running too rich or lean, i recommend u get one and see what ur motor is doing, its the ultimate engine checking tool and i think anyone with turbo that doesnt have a wideband guage or similar is just askin for trouble down the road, any little thing that changes in conditions has some type of result in the air fuel ratio. but ya i'd retune it asap u dont wanna blow **** up. too rich is bad also, u'll get fuel in ur oil and can blow bearings. I've seen it happen. hope this helps man, good luck
Old Mar 31, 2006 | 02:39 PM
EGinNY's Avatar
Default Re: Jus changed manifolds and...... (92gsrteg)
Bump!! Just put a new wastehgate on .....SAME problem
skateboard_ej8
Jun 21, 2012 05:57 AM
juniestyle
Apr 11, 2007 08:22 PM
ITR-T-GUY01
Nov 4, 2005 01:12 PM
sunscreen
Jul 2, 2002 05:40 PM
SIK IN DA HED
May 25, 2002 11:16 AM
