is this common???
Old Mar 28, 2006 | 06:35 PM
civicliveit's Avatar
Default is this common???
broken ringlands on 3 of the 4 pistons.
I have a b16 with a drag gen 3 kit, afc and fmu . was running 10 psi
Old Mar 28, 2006 | 07:28 PM
HamiltonRex's Avatar
Default Re: is this common??? (civicliveit)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by civicliveit &raquo;</TD></TR><TR><TD CLASS="quote"> afc and fmu . was running 10 psi</TD></TR></TABLE>
Yes
Old Mar 28, 2006 | 07:34 PM
Integra21's Avatar
Default Re: is this common??? (HamiltonRex)
hondata
/thread
Old Mar 28, 2006 | 07:35 PM
urbansi's Avatar
Yeah the AFC is bad news. The problem is that timing isnt corrected with the AFC, so detonation occures pretty easily unless you are on a somehwat conservative tune depending on weather, gas and so on.
Old Mar 28, 2006 | 07:47 PM
GS-R Civic's Avatar
stock pvc system?
Old Mar 28, 2006 | 07:51 PM
JDMB20TDA's Avatar
Default Re: is this common??? (GS-R Civic)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by GS-R Civic &raquo;</TD></TR><TR><TD CLASS="quote">stock pvc system?</TD></TR></TABLE>
why would this effect it ?
i mean the gasses do cause det but the FMU is a factor i wouldnt look past
Old Mar 28, 2006 | 08:02 PM
GS-R Civic's Avatar
Default Re: is this common??? (JDMB20TDA)
Maybe a bunch a little things adding up, just making sure all the angles are covered .
Old Mar 28, 2006 | 08:25 PM
*Boostwerks*'s Avatar
Theres this thing called timing. Its just as important, if not more than air/fuel ratio.
Better luck next time.
Old Mar 28, 2006 | 08:33 PM
Default Re: (Bryson)
well it lasted 4 years so i guess it was about time.
Old Mar 28, 2006 | 11:25 PM
komat's Avatar
Default Re: (civicliveit)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by civicliveit &raquo;</TD></TR><TR><TD CLASS="quote">well it lasted 4 years so i guess it was about time. </TD></TR></TABLE>
thats not bad then
my only lasted 3months
was at the dyno rasiing boost to 10-12psi and it blew at the end of a run
Old Mar 29, 2006 | 06:24 AM
tgreaves's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by civicliveit &raquo;</TD></TR><TR><TD CLASS="quote">afc and fmu .</TD></TR></TABLE>
Answered your own question..
97turboteg
Mar 25, 2006 09:36 PM
ultradx
Nov 15, 2005 12:36 PM
sohccrx
Feb 25, 2005 07:28 PM
respectblades
Feb 1, 2005 06:00 PM
TolnaPunk
Jan 11, 2005 10:36 PM
