Need new Valves and Valve Guides?
I have a LS turbo boosting 20 psi. I have K541M81 Wiseco Pistons (8.3 CR). I will have Crower turbo cams and Crower valve springs and retainers.
I was wondering if I should replace the stock valves or if they would handle it fine? If new ones, which would be the best for 300-350 HP?
Re: (YouCantCatchMe)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by YouCantCatchMe »</TD></TR><TR><TD CLASS="quote">stock valves are fine. take the head to a machine shop and have it checked, pressure tested, guides inspected, etc</TD></TR></TABLE>
Re: (PhatBoy5015)
I agree with what the others Said. No reason to change your valves or guides when building an engine unless they are damaged/worn. Have a machine shop check them and replace if needed.
