trying to problem shoot TPS
Old Apr 2, 2006 | 10:50 AM
spooledhonda's Avatar
* B A N N E D *
Default trying to problem shoot TPS
what will happen when your TPS gose bad or starts to go bad??????
Old Apr 2, 2006 | 01:18 PM
2muchPSI's Avatar
Default Re: trying to problem shoot TPS (spooledhonda)
It can cause lots of symptoms, for me it has mostly been bucking/hesitating at part throttle.
Get a multimeter and check your voltage at the sensor. It should be .45 closed and 4.5 WOT.
Old Apr 2, 2006 | 08:10 PM
Muckman's Avatar
Moderator in Chief
Default Re: trying to problem shoot TPS (2muchPSI)
What about if the signal is erratic? Like you see signal spikes when the throttle isnt being changed.
Old Apr 2, 2006 | 08:13 PM
dcturbols's Avatar
Default Re: trying to problem shoot TPS (Muckman)
yea the engine will idle funny and have patial throttle problems
Old Apr 2, 2006 | 10:01 PM
donkiman's Avatar
thats what it did to mine. You have to buy a new one used also, as honda wont sell it without the entire throttle body for $700. but used, very cheap.
Old Apr 4, 2006 | 05:40 PM
latindc2's Avatar
Default Re: trying to problem shoot TPS (donkiman)
Does it suppose to throw a code? mine does that hestitation...and idle ****....but no code....what do u guys recommend? gettin a new one? used? or do u guys know any chemicals that they sell at the local auto stores?
Old Apr 4, 2006 | 05:46 PM
vietjdmboi's Avatar
check your tps with a multimeter first. if its bad then no chemical will help fix an electrical problem. unless someone knows something i dont.
Old Apr 4, 2006 | 05:47 PM
EF9ZC's Avatar
no engine code.... u check ur ignition timing?
Old Apr 4, 2006 | 06:18 PM
STONEFACEKILLA's Avatar
a friend of mine is having the same problem, does any one know how to use the multimeter to check the voltage?
Old Apr 5, 2006 | 05:21 AM
* B A N N E D *
well i got a code 5 for a check light. i had my friend look it up for me and thats what he said it was. sooo i beleaved him, but i'm gona look up that code myself later today just to be sure.
Old Apr 5, 2006 | 06:25 AM
eflove's Avatar
Default Re: (spooledhonda)
the most common tps fail is a dead spot in it. this means that as you open the throttle the volts go up that is normal. With a bad tps the voltage will drop off in that spot so the car thinks you just closed the throttle. you can check the open and closed volts on the tps with a multimeter but the dead spot is allmost allways in the middle area of the tps's sweep. To test this you need a scope most people wont have that good luck
Old Apr 5, 2006 | 07:01 AM
VI Boost's Avatar
Default Re: (eflove)
when my tps was going bad my car was surging badly and i had part throttle problems like everyone said. you can find them new or used on ebay for about $25. i went to honda to try to get one and they said they could only sell me the whole throttle body for $820. i didnt get a code when it was goin bad though.
Old Apr 5, 2006 | 06:02 PM
Sci_v_icI's Avatar
Default Re: (VI Boost)
i have a 91 crx and im throwin code 7 which is tps but the car runs fine. i tried resetting the ecu and it still throws it. do u konw whats up with that??
Pinarr
May 18, 2012 08:36 AM
N2O INTEGRA
Sep 14, 2007 12:03 PM
crnimacak
Jan 19, 2006 04:59 PM
SIK IN DA HED
Dec 24, 2002 06:06 AM
