Anyone have a base map for 1000cc injector that idle fine??
after tunning part throttle. i can't get my car to idle at all. i was trying to get it to idle around 800rpm, but anywhere lower than 1k rpm the engine will died. Anyone have a base map of 1000cc injector they can burn me one?
forgot engine is an lsvtec 9:1 w/gsr head
Modified by eg:R at 6:55 AM 3/30/2006
Re: Anyone have a base map for 1000cc injector that idle fine?? (eg:R)
i tried like 5 diff basemaps for my b16 on 1000cc
none of them worked. all did the same
the idle will just surge up and down quick
Re: (96 GSR-T)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 96 GSR-T »</TD></TR><TR><TD CLASS="quote">his is the reason why I decided to run 750's instead of 1000's</TD></TR></TABLE>
Same problem here on 750's. I cant even drive to a dyno.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by komat »</TD></TR><TR><TD CLASS="quote">i tried like 5 diff basemaps for my b16 on 1000cc
the idle will just surge up and down quick </TD></TR></TABLE>
(To the original poster) Just get a wideband installed and tune it out. Since the surging/dying is caused by a rich/lean condition. Going rich then lean causes the idle surge, whereas the rich condition causes the dying.
I can e-mail you my tune... Im running a 3 bar though. My car idles like stock on 1000cc's
Kyle
Kyle
Re: Anyone have a base map for 1000cc injector that idle fine?? (N20civicB18)
I am running 1000cc injectors on the Apex'i Power FC and mine idles like stock..... dont know why alot of people have this problem
Re: (Unsivil_audio)
I have a 9.5:1 basemap for 1000cc injectors, fully built w/ ITR cams....
Tony1 burned the basemap for me.
Idles smoothly and runs like a champ.
Re: (JDM00SI)
I'm running 780's...on a D16, idling perfect @700rpm. I've noticed that you sometimes need to add 15-30% more fuel than calculated when you scale to <U>peak and hold </U>injectors. SOmetimes the motors I've dealt with will idle very rivh or lean, despite being warmed up, stock/larger injectors, closed or open-loop. My suggestion is to use the wideband, since things get tricky with very small pulsewidths.
If nothing else, start it up, adjust the FPR up/down until it will idle lower. If that works, you know which way to head.
i'm using hondata for tuning. i could have got some lower injector size, but when i made a post on what to get. most people were suggesting 1000cc to go with my setup. now the idle will surge around 1k to 1.3k rpm rough and after idle for a few min. the car idle will drop down to 200rpm and up to 800rpm and then will die out.
asianspeed
02-25-2003 07:19 PM
