bov adjustment
Old Mar 29, 2006 | 10:38 PM
spoolinegsr's Avatar
Default bov adjustment
so most turbo cars when i hear them rev, their turbo spools and they get a nice blow off out of their bov.....my car doesnt do that, but my bov doesnt even push any air when my car is idling.... do i need to loosen it up for this to happen. i can barely hear it at full throttle over my wastegate also. its a greddy type s on a gsr motor with 10 lbs of boost..... i dont really know whats going on, as i am really new to aftermarker turbo kits.....
Old Mar 29, 2006 | 10:54 PM
Hybrid_Coupe's Avatar
most of the cars you hear rev up and theyre bov opens are on really small turbos...youll notice it a lot on dsm's. once you get off the gas, during a shift you shouldnt hear your wastgate at all...wastegate only opens when you reach the set boost level to regulate the boost.
Old Mar 30, 2006 | 10:44 AM
dpetro1's Avatar
Default Re: bov adjustment (bluet1z06)
yeah depending on the size of your engine and the size of your turbo you may not blow off in neutral. mine barely does on my gsr with a 57 trim.
I would say that your best bet is to tighten your BOV as much as possible as long as you arent getting any compessor surge. That way its tight enough not to leak and loose enough not to surge.
Old Mar 30, 2006 | 01:21 PM
Default Re: bov adjustment (dpetro1)
so is this a normal flutter then?
http://videos.streetfire.net/v...4.htm
Old Mar 30, 2006 | 03:09 PM
Soccerking3000's Avatar
thats compressor surge...
Old Mar 30, 2006 | 03:13 PM
Default Re: bov adjustment (Soccerking3000)
what is that?
Old Mar 30, 2006 | 03:43 PM
the air trying to push its way back through the compressor and you get that fluttering noise
Old Mar 30, 2006 | 04:44 PM
does that just get fixed by tightening the bov? i guess i should learn how they work huh.....
Old Mar 30, 2006 | 04:55 PM
Meet07's Avatar
aint that a biocth....mine was doing the same thing when I was boosting my prelude?? more details.
Old Mar 30, 2006 | 04:56 PM
Meet07's Avatar
Default Re: bov adjustment (Meet07)
If thats the case then the Bov is....1) too tight or 2) not working??
bov is too tight
Old Mar 30, 2006 | 05:18 PM
cool, but i also am going to start looking for a better one, any suggestions....i want it to be loud!
Old Mar 30, 2006 | 05:28 PM
spoon95eg's Avatar
B A N N E D
From: Orange County / Palm Springs 714/76hoe, ca, usa
U want the loud one I have one laying on my garage its a rfl bov welded in the pipe I I lose the horn tho ready to go slap it in clamp it done!
Lmk email me or aim see sig
Old Mar 30, 2006 | 05:47 PM
Default Re: bov adjustment (spoon95eg)
cant afford it now
Old Mar 31, 2006 | 07:42 AM
dpetro1's Avatar
yeah def loosen the bov to get rid of that surge. either that or its not hooked up properly. it should give you that a nice crispy blow off after that.
xxscaxx
Mar 20, 2005 11:12 PM
JusT a Cx
May 5, 2004 11:30 AM
DownBoyDown
Feb 2, 2004 09:19 AM
iluvdrt
Oct 2, 2003 11:01 PM
Sleepin'
Nov 7, 2002 09:59 PM
