Drag Manifold Install question....
Old Mar 31, 2006 | 02:06 PM
EGinNY's Avatar
Default Drag Manifold Install question....
OK. ive been having a problem... https://honda-tech.com/zerothread?id=1576345
My question is, with a drag manifold can i mount the turbo on the drivers side???
(I know the downpipe is hanging, the pic was taken mid install.. the down pipe and dump tube are both on)
There are no visible leaks...
Does it affect anything at all??
Sorry if a dumb question...
Old Mar 31, 2006 | 02:15 PM
A.E Motoring's Avatar
Default Re: Drag Manifold Install question.... (EGinNY)
u want the cold side on the driver side like it is now? or u wannt mount the cold side on the pass side? if u have it set up one way already, then u need to make a new down pipe to mount it the other way
Old Mar 31, 2006 | 02:30 PM
EGinNY's Avatar
Default Re: Drag Manifold Install question.... (SPNFEDEH)
Its on amounted now like it is in the picture...
The down pipe and dump tube are done.....
I was jus curious if it matters wich way you mount the turbo to the manifold...
Old Mar 31, 2006 | 02:35 PM
no, just as long as everything bolts up fine
Old Mar 31, 2006 | 03:33 PM
H.A.R.T B18C1EG6's Avatar
looks fine.... as long as you have to issues
tuhboek
Feb 16, 2010 06:39 AM
tepid1
Oct 19, 2008 03:35 AM
bnut510
May 11, 2007 05:33 PM
mra4886
Apr 4, 2007 04:27 PM
B18EG6
Aug 6, 2002 11:18 AM
