DOHC ZC piston/con-rod cad file?
D16 piston/con-rod cad file?
Hi all,
Firstly, apologies as i already posted it in the crx forum but it was suggested I should post here too. Any help appreciated
I'm looking for a cad file(.dxf, .dwg or even a model) of a standard con-rod and/or piston so I can undertake a stress analysis of the part.
I need to analytically prove (it's my final year uni dissertation) that the amount of boost I plan to run can be withstood by standard internals.
Failing that, I'll have to model it myself, in which case has anyone got a dimensioned drawing so I don't have to measure the thing?!?!?
Thanks.
Modified by pugsleeuk at 2:17 AM 3/30/2006
Thanks.
Re: DOHC ZC piston/con-rod cad file? (pugsleeuk)
The dohc zc has the same rod as any d16 honda. So you can use/find/acquire one of them. As for the piston, they are a little different because of the huge head volume of the dohc ZC so they have a huge dome.
I have a box of d16 rods at home, if you want one and are willing to pay shipping id glady ship you one if you want it.
liam
Re: DOHC ZC piston/con-rod cad file? (liam821)
Thanks for the advice Liam,
I've amended the topic title accordingly.
I've got a con-rod but was trying to avoid measuring it if a drawing or model was readily available! If I had one I could just import it directly into the stress analysis software.
I'll give it a few more days then I'll resort to measuring. It'd be nice if I didn't have to because I can see getting some of the radii measurements accurate may be quite difficult and this would affect the results quite heavily.
Cheers.
Cheers.
