cant get datalogging to work.
Old Mar 31, 2006 | 06:58 PM
tuname420's Avatar
Default cant get datalogging to work.
i cant get dataloggin to work in ub or ecucontrol i got the ttl datalogging cable to blink red and green on the chip thing with j12 connected but it wasnt giving any good info at all it was way off when i revved it the maps did not show it. now im trieing to datalog in ecucontrol cut j12, set the com ports. What speed rate and stuff should i have? i pretty sure my cable and driver are working since i got it to blink green i still get it to make a connection one way but the red never comes on when i put my car in the on position? what else could this be? i need help ive been trieing to get datalogging working for more then a week with about 30 hours just trieing to get datalogging to work.
Old Mar 31, 2006 | 08:48 PM
tuname420's Avatar
Default Re: cant get datalogging to work. (tuname420)
bump
Old Apr 1, 2006 | 05:19 AM
HiProfile's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote &raquo;</TD></TR><TR><TD CLASS="quote">baud: 38400
other settings 8,n,1
flow control: none
and under advanced, I disabled the buffers.
check which com port its on (mine's was set @ Com2)
Firre up hypertermial, connect the tx/rx lines and see if it works (there's only three combos of connections, so try all 3). I have a guide to hypertermial on uberdata forums, I think under datalogging section titled something to the effect of "how to determine datalogging wires". Otherwise datalogging isn't enabled in the BIN (u opened it & saved the bin, right? not a uberdata/crome OEM basemap?), or user error. I know it took me a while, but I worked it out. Use Uberdata 1.70 (not 1.7, 1.7<U>0</U>), no jumpers modified, settings posted above, and it should work.
CubbyChowder
Apr 8, 2011 09:00 PM
user 93082343
Mar 11, 2009 10:17 PM
AnthraxVX
Jun 8, 2006 11:39 AM
Kutsuju_SLeePER
Nov 30, 2004 10:58 PM
