JRSC users please help!!!
Old Mar 29, 2006 | 11:53 AM
racerx159's Avatar
Default JRSC users please help!!!
I have something bugging me and this seems to be the only way I'm going to be at a peaceful state of mind. If you have a boost gauge, please read the following off of your gauge and let me know what you guys see. Turbo guys do not need to help with this because a turbo works differently from what I have been told.
When starting your engine after its completely cooled off (sitting for 3 hrs or overnight) what is your vacuum/boost gauge reading at (edit) when you first start it up?
Once your car has fully warmed up (the fan has turned on twice) what is your vacuum/boost gauge reading at?
You're help would be greatly appreciated in helping me not go insane about a little thing. Thanks alot.
Modified by racerx159 at 11:41 AM 3/30/2006
Old Mar 29, 2006 | 03:01 PM
nwmotorsports's Avatar
Default Re: JRSC users please help!!! (racerx159)
The gauge should read 0 when the motors off. 15-18in of vac at idle.
Old Mar 30, 2006 | 07:42 AM
racerx159's Avatar
lol, sorry, I just updated my post.
What I meant was what is the idle at when you first start the car after being off for a while. The cold Idle reading and then the warm idle reading. Thanks alot
Old Mar 30, 2006 | 11:25 AM
racerx159's Avatar
Default Re: (racerx159)
bump for current jrsc users....
Old Mar 30, 2006 | 11:34 AM
LuderCriS's Avatar
mines is at -20 at idle 0 when motor is off
Old Mar 30, 2006 | 12:19 PM
racerx159's Avatar
Default Re: (PreludeRGuY)
lol, I dont need the reading when the car is off. I need the reading with the car running cold and the car running warmed up.
ok, let me see if I can simplify what I'm saying.....
Once the car has been off for about 1-2 hours start the car and look at the vacuum reading then, with the car running.
Take a nice little spin so that the engine fully warms up and stop. Dont turn the car off. What is the vacuum reading with the car running now that the car is fully warmed up.
Old Mar 30, 2006 | 07:46 PM
racerx159's Avatar
someone please hook me up
Old Apr 4, 2006 | 09:40 AM
Gojira D.O.T's Avatar
cold start idle should be around 1500rpm till the engine starts to warm up then it should slowly drop to around 750-800rpm
Old Apr 4, 2006 | 10:31 AM
racerx159's Avatar
Default Re: (Gojira D.O.T)
I'm not talking about the idle rpm when cold and then warm. I'm talking about the vacuum reading when cold and then warm.
Old Apr 4, 2006 | 10:37 AM
SovXietday's Avatar
Just went out and checked to make sure.
-20 Cold
-20 Warm
What are you reading?
Old Apr 4, 2006 | 10:44 AM
racerx159's Avatar
Default Re: (SovXietday)
-20 when cold and then after ten minutes of driving and the fan turning on twice at idle I read -22. How long did you let the car sit? How many times did the fan come on, fully warm is when the fan turns on twice, technically
Old Apr 4, 2006 | 11:00 AM
SovXietday's Avatar
I just turned it on to see where it sat, it was -21/-20. I know that it reads the same when it's warm, so I just wanted to see where it sat cold. Is your charger running weird, or were you just curious as to if it was normal?
Old Apr 4, 2006 | 11:03 AM
racerx159's Avatar
I was curious to see if the readings I was getting were normal. Maybe the hondata intake manifold is a little worn and tends to leak a little till the mani warms all the way up and seals better. hmmm, any other ideas?
btw, my charger isn't running weird, its a'ok.
JDM_Risa
Aug 11, 2005 03:26 AM
B16Civic93
Mar 19, 2005 07:00 PM
Eskay@JDMCircle.com
Oct 6, 2004 09:43 PM
wickedxboi
Feb 28, 2003 10:21 AM
d mafia
Oct 30, 2001 06:23 PM
