Is this repairable??
Old Mar 28, 2006 | 07:38 PM
bigwhitebucket's Avatar
Default Is this repairable??
Just wondering if any of you have seen this happen. I have it bolted up to the head, but I'm afraid if it heats up it will crack the expansion slot all the way through. Lemme know if anyone has any remedies for this.
Old Mar 28, 2006 | 07:41 PM
T3T495GSR's Avatar
Default Re: Is this repairable?? (bigwhitebucket)
wow, how did that happen? From the looks of it , it doesnt look like a huge problem
Old Mar 28, 2006 | 07:47 PM
Default Re: Is this repairable?? (T3T495GSR)
I sent it back to the to company that made it for a repair and it came back this way; in an empty cardboard box.
Old Mar 28, 2006 | 07:52 PM
1Bar GSR's Avatar
That is suppose to be there. It is made for when the manifold heats up and expands. So when it contracts it doesnt crack. Its not going to hurt anything.
Old Mar 28, 2006 | 07:59 PM
urbansi's Avatar
Default Re: Is this repairable?? (1Bar GSR)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 1Bar GSR &raquo;</TD></TR><TR><TD CLASS="quote">That is suppose to be there. It is made for when the manifold heats up and expands. So when it contracts it doesnt crack. Its not going to hurt anything.</TD></TR></TABLE>
I really hope that you are joking, but if not SSAC has apparently had the right idea this hole time
Old Mar 28, 2006 | 08:17 PM
B18C1CYA's Avatar
it looks like a slot was cut there and it shifted quite a bit , i would try bolting it down and see what happens , it might pull back to shape
Old Mar 28, 2006 | 08:23 PM
Default Re: Is this repairable?? (B18C1CYA)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by B18C1CYA &raquo;</TD></TR><TR><TD CLASS="quote">it looks like a slot was cut there and it shifted quite a bit , i would try bolting it down and see what happens , it might pull back to shape </TD></TR></TABLE> Yeah there are expansion slots cut between 1-2 and 3-4. I'll try to take a few pics later to show the other side of the flange where it's about the break all the way through. Not sure how much further that runner will dip if it breaks??
Old Mar 28, 2006 | 08:29 PM
onemanlan's Avatar
It would seem that the engine movment during heavy load and gear shifts would cause the turbo to rock back and forth, thus pulling the manifold with it. I think that action right there would cause those points to strip the bolts holding the mani on there.
Keep in mind I'm not expert, but that looks like a possiblility.
Old Mar 28, 2006 | 10:02 PM
dunkd's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by bigwhitebucket &raquo;</TD></TR><TR><TD CLASS="quote"> Yeah there are expansion slots cut between 1-2 and 3-4. I'll try to take a few pics later to show the other side of the flange where it's about the break all the way through. Not sure how much further that runner will dip if it breaks??</TD></TR></TABLE>
it is supposed to be cut all the way through.
Old Mar 28, 2006 | 10:41 PM
D@nnY's Avatar
the flange warps when they weld it and it shifts....it should be bolted down to a head when welded or milled afterwards to make it flat
Old Mar 28, 2006 | 11:54 PM
ozzyman's Avatar
Default Re: Is this repairable?? (dunkd)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dunkd &raquo;</TD></TR><TR><TD CLASS="quote">
it is supposed to be cut all the way through.</TD></TR></TABLE>
Correct. Full-Race, LoveFab and some other companies do this for expansion when the manifold heats up.
Taken from the Full-Race website.
Old Mar 29, 2006 | 12:38 AM
ImportMotorSpec's Avatar
Default Re: Is this repairable?? (ozzyman)
The manifold would have a more likely chance to crack if the cracks werent there and it had all the stress all the time. Im pretty sure the companies that know what there doing when it comes to fabrication all have slots cut.
Old Mar 29, 2006 | 10:22 AM
1Bar GSR's Avatar
Default Re: Is this repairable?? (urbansi)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by urbansi &raquo;</TD></TR><TR><TD CLASS="quote">I really hope that you are joking, but if not SSAC has apparently had the right idea this hole time </TD></TR></TABLE>
No I was not joking. That is why they are there.
snaileg
Mar 3, 2012 04:50 PM
frankbe999
Mar 27, 2007 12:39 PM
ATYPR
Nov 8, 2006 08:50 AM
Fat Chick Magnet
Oct 9, 2006 10:19 AM
junkyard racer
Welding / Fabrication
17
Oct 7, 2004 05:29 PM
