Built b18b having sputtering problems
Old Apr 1, 2006 | 04:01 PM
urbansi's Avatar
Default Built b18b having sputtering problems
Modified by urbansi at 10:07 PM 5/22/2006
Old Apr 1, 2006 | 11:53 PM
urbansi's Avatar
Default Re: Built b18b having sputtering problems (urbansi)
ttt
Old Apr 2, 2006 | 06:14 AM
Spec R's Avatar
you might be running super rich, which is causing the bogging at 4500...but as for the low compression numbers...did u pull the Fuel injection fuse? pull all the plugs out, and do the compression test while pressing the accelerator to the floor.
i remember at school once i did a compression check with all plugs in, and no WOT, and i got a 90 psi reading across the board. i was laughed at that day since no one wanted to believe me about the "correct" procedure. the next day i did it right, and got 195 across.
Old Apr 2, 2006 | 11:33 AM
urbansi's Avatar
Default Re: Built b18b having sputtering problems (Spec R)
Yeah the compression test was done correctly.
The thing that just makes me wonder is why all of the sudden the car would start sputtering, never did it till that one day and now it does it all the time.
Old Apr 2, 2006 | 03:30 PM
Spec R's Avatar
i dont know then...process of elimination i guess now.
Old Apr 2, 2006 | 04:55 PM
urbansi's Avatar
Yea thats what i have been doing.
Old Apr 2, 2006 | 05:06 PM
Sketch_hs's Avatar
did you check the settings on the afc?
Old Apr 2, 2006 | 07:31 PM
urbansi's Avatar
Default Re: (Sketch_hs)
Nothing has changed on the AFC since the car was bought.
I hate those things sooo much
Old Apr 8, 2006 | 10:19 AM
urbansi's Avatar
Default Re: (urbansi)
Sputtering actually went away. Got a full tank of gas in the car and then realized that someone drilled a hole in the tank from the inside of the car possibly while trying to ground an amp. to the owner, i leave for 5 days and he almost blows himself up.
LonnyEnds
Jul 2, 2014 07:57 PM
flangemastermike
May 31, 2006 08:13 AM
JDM EJ1 95
Sep 8, 2004 09:15 AM
shadowdawn
Oct 20, 2002 09:59 AM
not so civic
Aug 29, 2002 05:09 PM
