Injectors and FMU
Old Mar 29, 2006 | 01:44 AM
laakea's Avatar
Default Injectors and FMU
Can anyone help me out? I'm trying to figure out what type of fmu to get, 12:1, 10:1, just not sure. I have 310 injectors, 255 fuel pump, AEM fuel presure regulator, and fuel psi is at 42-43.
The rest of my setup is going to be T3/T4 turbo, map bypass, 6 psi boost, Apexi VAFC. Any help or suggestions would help. Thanks.
Old Mar 29, 2006 | 07:28 AM
rhd_ej coupe's Avatar
Default Re: Injectors and FMU (laakea)
whats the application for? turbo supercharger all motor? I'm running a turbo it a fmu at 12.1 and 240cc injectors at 35 psi. why are you so high in psi?
Old Mar 29, 2006 | 08:48 AM
Redline130's Avatar
Default Re: Injectors and FMU (rhd_ek coupe)
It says in his post he has a turbo. If you are using a FMU, you should be using the stock injectors. If you want to use the 310's that you have, ditch the FMU and just use the VAFC to fine tune your fueling.
Old Mar 29, 2006 | 08:54 AM
Everyones Hero's Avatar
Default Re: Injectors and FMU (Redline130)
You're better off using a program like Crome (www.pgmfi.org)
FMU & bigger injectors won't work. Well, they might be okay for boost, but in VAC you're going to run so rich you're fuel economy will go to **** and you'll probablly wash your cylinder walls and blow your piston rings.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by rhd_ek coupe &raquo;</TD></TR><TR><TD CLASS="quote">whats the application for? turbo supercharger all motor? I'm running a turbo it a fmu at 12.1 and 240cc injectors at 35 psi. why are you so high in psi?</TD></TR></TABLE>
Stock is around 40-42psi. Why are you running so low with your fuel pressure?
Old Mar 29, 2006 | 08:20 PM
laakea's Avatar
so no fmu and tune with just the vafc. will i also be adjusting the fuel pressure regulator for tuning too?
will it cause any harm to use the 310's? or will it just be more difficult to tne on the dyno?
by the way, i'm in honolulu. howzit redline130.
Old Mar 29, 2006 | 08:22 PM
laakea's Avatar
oh yea... will i just be causing myself problems if i do use a 12:1 fmu, 310's, and vafc all together?
i get one stock engine too.
Old Mar 29, 2006 | 09:11 PM
riceburnerryan's Avatar
f u c k FMU get chrome or uberdata ..
Old Mar 30, 2006 | 12:36 AM
Redline130's Avatar
Default Re: (laakea)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by laakea &raquo;</TD></TR><TR><TD CLASS="quote">so no fmu and tune with just the vafc. will i also be adjusting the fuel pressure regulator for tuning too?
by the way, i'm in honolulu. howzit redline130.</TD></TR></TABLE>
Howzit. Like the others have mentioned, avoid the fmu if you can. If you can get your hands on a program like Crome or Uberdata, that would be your best bet. If not, you can tune with the VAFC and the 310's. I have a feeling that the 310's may end up not being able to supply enough fuel. BTW, I'm on the Big Island. Where will you be dynoing at?
Old Mar 30, 2006 | 12:38 PM
laakea's Avatar
don't know of any dynos... still new to the island.
Old Apr 1, 2006 | 12:39 AM
laakea's Avatar
so the 12:1 fmu, 310's, 255 walboro fuel pump, map bypass sensor, msd 6al, msd ss coil, and VAFC will work together? tell me what you think.
Old Apr 1, 2006 | 10:29 AM
Redline130's Avatar
You shouldn't use the FMU with the 310 injectors. If you do want to use the FMU, stick with the stock injectors. If you are going to use the 310's, use the VAFC to fine tune it. If you already have the MSD stuff, then use it. If not, they are not necessary, the stock ignition system will be fine.
Old Apr 3, 2006 | 07:13 PM
laakea's Avatar
Thanks for the advice.
spoon95eg
Dec 19, 2005 06:15 PM
slow02ss camaro
Apr 8, 2003 06:50 PM
freeplay
Dec 8, 2002 11:03 AM
interlude91
Jun 26, 2002 02:01 AM
BoostedSi
Feb 15, 2002 01:31 PM
