Compression test?
Old Mar 31, 2006 | 05:30 PM
allmotorsi04's Avatar
Default Compression test?
what type of numbers should i be looking for w/ 9:1 pistons in a b16? just curious if it is any different than a stock b16
Old Mar 31, 2006 | 05:45 PM
komat's Avatar
Default Re: Compression test? (allmotorsi04)
8.5:1~9.5:1 compression: 170-210 psi per cylinder
Old Apr 1, 2006 | 03:24 PM
Default Re: Compression test? (komat)
my did 150 across the board? good bad? on what i believe is 9:1 pistons
Old Apr 1, 2006 | 03:55 PM
abnaasefmb's Avatar
did you open the tb while you were cranking?
Old Apr 1, 2006 | 05:09 PM
Default Re: Compression test? (abnaasefmb)
no....is that my problem?
Old Apr 1, 2006 | 05:48 PM
just did compression test with throttle body wot......175 across.......that's better i believe?
Old Apr 1, 2006 | 05:51 PM
SpeedingHatch's Avatar
yes, thats better. But try and do one wet as well and see if the numbers jump alot.
But it seems like youre in good shape
Old Apr 1, 2006 | 06:06 PM
kameleon23's Avatar
I have 9:1 compression in my B16, and run 185 across the board.
Old Apr 1, 2006 | 06:17 PM
Default Re: Compression test? (kameleon23)
do one wet?
Old Apr 1, 2006 | 06:34 PM
yes, pour a dab of oil in the cylinder and redo it. The numbers will most likely be higher.
I usually fill the cap from the quart of oil, then pour it in.
You dont have to, but its a suggestion.
KDawg08
Mar 7, 2012 10:38 PM
avex
Apr 23, 2004 08:34 AM
lothian110
Oct 28, 2003 09:24 PM
lothian110
pagong
Jul 7, 2001 07:47 PM
