could there be fuel pump problems,due to runnin under half a tank,gettin on it!
Re: could there be fuel pump problems,due to runnin under half a tank,gettin on it! (Dturbocivic)
I never run less than half a tank at the track. I saw a thread on here where someone didnt have enough gas and when they made a pass the fuel pump sucked in some air and he blew his motor.
Re: could there be fuel pump problems,due to runnin under half a tank,gettin on it! (TurboCoop)
I think you would have to have a lot less than half tank with a stock location pickup. I would notice my old turbo single cam would run .5-.75 AFR points leaner if the gauge was reading just under the red line. Im sure if i ripped some long corners or something it would have gone too lean but I was careful when it was that low.
Re: could there be fuel pump problems,due to runnin under half a tank,gettin on it! (Bailhatch)
I have had the car lean out in 4th gear at the track due to a low fuel level in the tank. I pumped in 2 gallons and the problem went away. This was with a 255lph walbro. I've had it happen with 1/4 tank on the fuel gauge.
Jonathan_ED3
05-20-2008 03:04 PM
h22civic95coupe
12-05-2003 11:07 PM
91integraLSVTEC
10-26-2003 07:52 PM
