Innovative T61 ITS?
Innovative T61 ITS?
How good of a turbo is this, I found one used for a good deal. It comes with an S cover, .63 A/R exhaust housing, a stage five turbine wheel, and a 360 degree thrust bearing and they want $550.00 for it.....should i grab it, I was looking at an 60-1 or SC61...this turbo is right in line with them right. I was concerned with the Stg 5 Wheel and that it might be laggy on my 81.5mm GSR
Re: Innovative T61 ITS? (96 GSR-T)
That turbo should'nt be to much laggier than the 60-1, It will have a much larger top gain than the 60-1. If it's in good condition, you really can't go wrong. Also if you do more drag racing, then this is the turbo for you. Otherwise I would wait and get the turbo you exactly want.
Re: (mrbsponge)
Did you have the Stg5 wheel on your B16, and what A/R were you running and when did you reach full boost in your car....sorry for the 50 questions. I know this is the biggest wheel you can stuff into one of these turbos and is reportedly bumps the power output about 50whp over a Stg3. I dont do much drag racing at all but I would hate to pass this deal up.
Frozen E
04-13-2006 02:50 PM
