What injector clips do I need?
Old Mar 30, 2006 | 05:50 PM
RTW DC2R's Avatar
Default What injector clips do I need?
Did some searching, but got confused.
Working on my build, just picked up a set of 1000cc Precisions, need to get clips. Whats different between OBD1 and OBD2 clips? just the clips themselves, or the wiring? Going to be running P28 OBD1 ECU with OBD2 -> OBD1 harness but Im not sure if I need OBD1 or OBD2 clips, or if there is even a difference. My current stock OBD2 clips had to be rewired because the original harness was cut and stolen, and I know whatever I get I will have to rewire those with my FJO box.
Old Mar 30, 2006 | 05:54 PM
damnraz's Avatar
Default Re: What injector clips do I need? (RTW DC2R)
I don't think there is a big difference between the obd1 and obd2 injector clips, the only thing I can tell you is that the obd2 is slightly different due to the design of the clips themselves, the wiring is basically the same but the housing is different. I know because I pulled out the two pins from the obd2 housing and connected to an obd1 b18c1 in an EK and it worked fine
WHY7SPOOLIN
Mar 11, 2015 01:52 AM
Black R
Nov 10, 2007 04:31 PM
RBNightMare
Feb 13, 2007 11:50 AM
EKB18BPR3
May 6, 2005 08:07 AM
SilverEk3dr
Sep 24, 2003 08:20 AM
