nSandwich plate work with OEM GSR oil cooler?
Does anyone know if there is a sandwich plate that works with a 95 GSR oil cooler. The oil filter bolt? looks too short to hold both the the oil cooler and the sandwich plate. Anybody with a 95 gsr have a sadwich plate thanks.
Any a good place to buy one
Modified by HT Chaplin at 9:29 AM 3/30/2006
Re: nSandwich plate work with OEM GSR oil cooler? (HT Chaplin)
The Golden Eagle sandwich plate was designed to work with the stock oil cooler. There is no issues when using the two together
Re: nSandwich plate work with OEM GSR oil cooler? (Mazda 3 Racer)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Mazda 3 Racer »</TD></TR><TR><TD CLASS="quote">The Golden Eagle sandwich plate was designed to work with the stock oil cooler. There is no issues when using the two together </TD></TR></TABLE> True, it will work just fine, I've seen this done many times, and golden eagle make a nice plate, and is cheaper than greddy's.
Re: nSandwich plate work with OEM GSR oil cooler? (Mugencrxsir1)
Ok thanks!
i looked at them online and there is multiple setups (diff size bosses) im guessing to run the standard -3An oil feed line i could use a sandwich plate with a 1/8NPT boss?
thanks
thanks
Or you could get an aftermarket cooler then get this adapter:
I have this one (got it from the site below). I also have the golden eagle for the ls/vtec then use this mocal one on top of the GE for the cooler.
"This lightweight, compact high flow sandwich plate incorporates a 180 deg. F thermostat to regulate oil flow to the cooler until the engine is properly warmed up. 1 5/16" thick with 1/2" NPT female ports."
Site: http://www.racerpartswholesale.com/index.html --> Click on mocal products in the left hand column.
Re: nSandwich plate work with OEM GSR oil cooler? (Dunc)
You could get very similar plates from ebay, check this out $38 http://cgi.ebay.com/ebaymotors...&rd=1
Just FYI, if the oil is captured from the oustide of these plates, that means it is unfiltered. The filtered oil runs through the center of ANY sandwich plate. The GE plate uses filtered oil so no contaminents will damage turbo's, gauges, sensors, etc. If your plate's ports do not intersect with the center post of the plate, then you have unfiltered oil. Just thought I would remind everyone.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Mazda 3 Racer »</TD></TR><TR><TD CLASS="quote">Just FYI, if the oil is captured from the oustide of these plates, that means it is unfiltered. The filtered oil runs through the center of ANY sandwich plate. The GE plate uses filtered oil so no contaminents will damage turbo's, gauges, sensors, etc. If your plate's ports do not intersect with the center post of the plate, then you have unfiltered oil. Just thought I would remind everyone.</TD></TR></TABLE>
That plate serves a completely different purpose than your GE plate.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Dunc »</TD></TR><TR><TD CLASS="quote">Are you talking about the one I posted about?</TD></TR></TABLE>
The one you posted is for an oil cooler loop, the GE one is simply for gauges or feeding a head or turbo fresh oil. Two totally different ptoducts.
Re: nSandwich plate work with OEM GSR oil cooler? (nfn15037)
Well it works for me...maybe that's because I'm using the GE for my head/turbo and the Mocal one for the oil cooler haha
But now I'm confused and missing the point of stating they are different since we already knew that. He wanted a sandwhich plate that would work for an oil cooler....the one I posted does just that.
Also to go back to his original question, the one I posted also has it's own bolt that comes with it. So all you do is spin it on the current bolt out of the block and then you can attach the oil filter to the Mocal plate.
null.
05-11-2007 07:01 PM
null.
05-01-2007 12:01 PM
