fuel problem..pics/explanation inside
Old Mar 30, 2006 | 08:09 PM
second edition's Avatar
Default fuel problem..pics/explanation inside
So i ordered this fuel line
i also have this rail
this is the setup I have now
The fuel line mounts directly to the filter.Im going to mount the fuel gauge to the rail, thats not a problem, i wanted to do that anyways. I dont know what to do with the fuel pressure sensor though......thats where you guys come into play
Old Mar 30, 2006 | 08:36 PM
black98gsr-t's Avatar
Default Re: fuel problem..pics/explanation inside (second edition)
are u using the stock fuel pressure reg.???
if so i'd just use the sensor for the in car gauge .. the mechanical will really only help when your under the hood ..
Old Mar 30, 2006 | 08:55 PM
Default Re: fuel problem..pics/explanation inside (black98gsr-t)
im running a b&m pressure regulator...I need to find a place to mount the sensor for my electric fuel press. gauge
Maybe i can drill and tap the fuel rail for it
Old Mar 30, 2006 | 09:04 PM
u might try tapping the plug at the end of the rail by the reg or find an adapter fitting.. just in case u change the fuel setup later u have no perm. damage to the fuel rail..
Old Mar 31, 2006 | 03:54 AM
vietjdmboi's Avatar
why dont you just take out the plug you have on the AEM fuel rail and put both the gauge and sensor there with a "T" fitting? it shouldnt interfere with the fpr.
Old Mar 31, 2006 | 05:39 AM
MoonScryer's Avatar
Default Re: (vietjdmboi)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by vietjdmboi &raquo;</TD></TR><TR><TD CLASS="quote">why dont you just take out the plug you have on the AEM fuel rail and put both the gauge and sensor there with a "T" fitting? it shouldnt interfere with the fpr.</TD></TR></TABLE>
Also, you won't have such a long harness on your fuel sensor.
Old Mar 31, 2006 | 07:36 AM
thats what i came up with last night ...I hope it works
boost4s2k
Honda S2000
Aug 17, 2009 05:38 PM
Jayzeroone
Jun 20, 2005 03:59 PM
AlxSiR7
Dec 25, 2004 01:19 PM
AgentJam
Oct 26, 2004 04:33 PM
Accord EX F22
Aug 9, 2001 05:07 PM
