NO POWER PLEASE HELP!!
Old Apr 2, 2006 | 03:07 PM
TarProductions's Avatar
Default NO POWER PLEASE HELP!!
Ok i am reposting this for a friend who has a spec v we ran into some problems. Any ideas would be greatly apreciated.
Well I pulled the engine to paint the engine compartment and when putting back in installed an ssr turbo kit with an safc2. Long story short made sure everthing was buttoned up all fluids were good, put the battery in and everything, even the safc was keying hot and powering properly. When I tried to crank it sounded like there was not enough power to turn it over so i hooked up a jumper box to give it that xtra kick and boom everthing is dead as in absolutly no power not even the door dinger. Checked all under hood fuses and relays and under dash fuses, and they are all good. power is going to and thru the fuse box and to starter. im stumped ! Any help or suggestions would be great. Thanx.
Modified by TarProductions at 4:29 PM 4/2/2006
Modified by TarProductions at 5:22 PM 4/2/2006
Old Apr 2, 2006 | 03:15 PM
coneheadsracing's Avatar
Default Re: NO POWER PLEASE HELP!! (TarProductions)
Did you clean up the grounds after painting?
Old Apr 2, 2006 | 03:19 PM
Default Re: NO POWER PLEASE HELP!! (coneheadsracing)
We didnt sand the paint down underneath the grounds because we thought the screw going into the metal would be enough. Should we sand a to the body under the grounds?
Old Apr 2, 2006 | 08:30 PM
StylishDOHC's Avatar
yep sounds like a ground problem...take a little 80-100 grit and sand it to bare metal, especailly on the battery ground.
B00sted Eg2
Oct 3, 2012 06:33 PM
01typerboi
Mar 29, 2011 04:02 AM
authentic plusONErandy
Aug 14, 2007 04:45 PM
TarProductions
Apr 3, 2006 01:40 PM
TarProductions
Apr 2, 2006 07:02 PM
