Should i run this setup?
Old Mar 30, 2006 | 01:52 PM
lhsabes's Avatar
Default Should i run this setup?
Need some suggestions, im new at this Honda thing so help me out on what i should do. Iwant somewhere around 300hp.
b18c1
block guards by dart
JE pistons w/ compression of 10:1
Crower Rods
3 angle valve job
skunk2 valve set
unorthodox crank pulley
skunk2 adjustable cams
custum the camshaft lobes to about 282 degrees of rotation
Moroso oil pan with the spoon oil plug
spoon radiator
msd ingnition the whole set
msd wires
msd dizzy cap
NGK iridium spark plugs
Hondata S200 ecu
Garrett t3/t4 turbocharger
Greddy BOV
Big *** ebay intercooler
1000cc injectors from R/C
AEM fuel regulator
Walbro fuel pump
Old Mar 30, 2006 | 02:10 PM
Dunc's Avatar
BCICAN
Default Re: Should i run this setup? (lhsabes)
Surely. That's plenty to make 300+
Old Mar 30, 2006 | 03:49 PM
boostedcivicsir's Avatar
Mr. Badwrench
Default Re: Should i run this setup? (Dunc)
the injectors may be overkill, 650-750's should suit you fine but youll be ok with that setup.
Pandahatch
Feb 2, 2008 02:27 PM
B18Sleeper
Aug 7, 2005 04:21 PM
Bspec18
Jun 23, 2003 03:31 PM
yimmy
Jan 24, 2003 11:57 PM
