Revhard or DRAG turbo manifold?
I have both of these manifolds and both are ac/ps compatible and im wondering if one is better than the other. I think the REVHARD looks beefier but both have poor WG location.
Whatever, i own both currently and im trying to decide which to keep between the two... help me decide!
DRAG:
REVHARD:
I would clean whichever one i chose up of course
Thanks
DRAG:
REVHARD:
Thanks
Re: (Bryson)
They both suck, but the thing with the DRAG mani is the bolt in the bottom middle...that's a biaaaaaatch to get to. Shouldn't be as bad with the the RevHard
Re: (H.A.R.T B18C1EG6)
I would use either as well. I use a drag mani and it works fine. Just clean it up and paint it with some good hi temp paint thats what I did to mine and it makes it all pretty.
Re: (Soccerking3000)
Use the revhard for sure. Thats what im using, and i have no spike/creep issues with a tial wastegate. definately clean it up a little though.
good luck.
good luck.
chubz0r,
yeah the revhard seems like it has much bigger runners. Is your revhard ac/ps compatible? Also do you have any issues with the wastegate hittin the hood?
I know when i was running the DRAG the wastegate cracked my CF hood
Re: (turbotime)
Yeah the revhard is ac/ps compatible. The compressor side of the turbo is on the passenger side. My tial also hits my hood, but i just used an elbow between the manifold and wastegate. So its fine now.
grab an elbow. i dont know where but im sure u can find one just search around here.
NICE, thanks, spoolinperformance sells the elbow.
Any tips on how to clean cast iron? I was just gonna get a stiff steel brush for a drill and see what i can do. Im just confused on how to clean the inside?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Soccerking3000 »</TD></TR><TR><TD CLASS="quote">sandblast it</TD></TR></TABLE>
i dont got tools for that how much would a shop charge for that, or what would be a fair price?
Re: (turbotime)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by turbotime »</TD></TR><TR><TD CLASS="quote">i dont got tools for that how much would a shop charge for that, or what would be a fair price?</TD></TR></TABLE>
It would literally take 10-15mins to blast that, if that much time. Just walk in and ask them how much to bead blast it. They shouldn't charge that much @ all. If they quote you a high price I would just walk out and try another shop.
Re: (turbotime)
drag manifold = boost creep at high rpm, not enough relieve for wastegate flow
revhard = not hte best, but i'm boosting 10 psi and got solid 10 psi everytime for one year already., I used it with tial WG
Re: (elpiar)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by elpiar »</TD></TR><TR><TD CLASS="quote">drag manifold = boost creep at high rpm, not enough relieve for wastegate flow
revhard = not hte best, but i'm boosting 10 psi and got solid 10 psi everytime for one year already., I used it with tial WG</TD></TR></TABLE>
also the collector area is different, look at these pics of the two sidebyside
DRAG:
REVHARD:
DRAG:
REVHARD:
Re: (cmGSR916)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by cmGSR916 »</TD></TR><TR><TD CLASS="quote">the revhard mani will not fit drag dp is what i was told before. i was kinda on the same boat back then. the drag manifold works fine for me at 7-10psi. </TD></TR></TABLE>
yeah ill prolly cut and reweld the drag 5 bolt flange or something
Re: (turbotime)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by turbotime »</TD></TR><TR><TD CLASS="quote">does anyone know for sure if that revahrd is ac/ps compatible? also will it work with the DRAG downpipe?</TD></TR></TABLE>
yes it is ac compatible
and no boost spike/creap, dont get a log mani, revhard is a whole lot better
Re: (boosted94cx)
did anyone find out why the drag manifold creeps. I understand that the wastegate is in a bad location but some have spikes/creeps and others dont???
Re: (Meet07)
Rev hard is actually a decent manifold. I been using it for over 3 years with great success. I just went 10.9 @130 using a rev-hard manifold and a sc-61 only boosting 22lbs. I would say its good till around 400-450whp before it starts to rob major power.
Adriano
Adriano
Re: (Adriano)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Adriano »</TD></TR><TR><TD CLASS="quote">Rev hard is actually a decent manifold. I been using it for over 3 years with great success. I just went 10.9 @130 using a rev-hard manifold and a sc-61 only boosting 22lbs. I would say its good till around 400-450whp before it starts to rob major power.
Adriano</TD></TR></TABLE>
"only" 22 lbs
"only" 22 lbs
