Turbo Coolant Lines HELP SETUP
Ok im doing a HMT kit on my car and picked up a little T3 .42/.48 (i believe) off of a Saab. Anyways this turbo has coolant lines and oil lines. I know how and were to run the oil lines, but i've been searching and found little to no information on how to run the coolant lines. Does anyone have a writeup on it or can tell me how to run them? Im buying a full oil line and coolant line kit from Fast-Turbo next week and than next weekend i will be installing everything (hopefully). So please guys just give me some help. Also its going on a SOHC Y7 motor w/ a Y8 Manifold. If that helps...
Thanks in advance
Thanks in advance
What motor do you have?
You can run the coolant lines to the inlet/outlet on the side of the intake manifold (on throttle body side)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Autoworks »</TD></TR><TR><TD CLASS="quote">What motor do you have?</TD></TR></TABLE>
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by IWANTAHB »</TD></TR><TR><TD CLASS="quote">Also its going on a SOHC Y7 motor w/ a Y8 Manifold. If that helps... </TD></TR></TABLE>
If you search for Turbo coolant lines there are about 27 threads on it. I think the best place for you to tap them will be the heater hoses (if you still have them installed).
Thanks in advance</TD></TR></TABLE>
owned by the ninja edit
RTW DC2R
May 14, 2006 03:01 PM
