New 1/4 mile times for my turbo D16
Went out to the Bradenton 1/4 mile last night for need2speed.com's track day. It was a slicks and drag radials only event. This is a new best for my turbo D16. Runs were done with 22x8x13 M&H and open diff. It was pretty busy so this was the only run of the night.
R/T .512
60' 1.697
330' 5.260
1/8 8.150
MPH 86.27
1000' 10.683
1/4 12.804
MPH 105.88
Modified by RyanEJ8 at 5:11 PM 8/13/2006
R/T .512
60' 1.697
330' 5.260
1/8 8.150
MPH 86.27
1000' 10.683
1/4 12.804
MPH 105.88
Re: New 1/4 mile times for my turbo D16 (RyanEJ8)
Setup:
Block:
SRP Pistons with JE Rings approx 10:1 C/R and .020 overbore
Eagle Rods with ARP Rod Bolts
Golden Eagle Block Guard
Stock Crankshaft/Girdle/Oil Pump/Water Pump
Stock Oil Pan
Head:
ZEX 105300 Street/Strip Camshaft
ZEX Valve Springs with Stock Retainers
AEM Adj Cam Gear
ARP Head Studs
Stock Valves
Drivetrain:
ACT Street Disk and Heavy Duty Pressure Plate
Stock Y8 Tranny
Stock Axels
Fuel and Tuning:
RC 750cc saturated injectors
AEM Fuel Rail/Fuel Filter/FPR
Holley 255lph High Pressure Fuel Pump
Stock Ignition and Wires
Hondata S200
Turbo Setup:
Precision SC50 .48 A/R
Precision AS1025 600hp intercooler
Lovefab SST Manifold
Lovefab Downpipe
Tial 38mm Wastegate
Tial BOV
Greddy Profec B Spec II Boost Controller
SVE 3bar Map Sensor
Block:
Stock Oil Pan
Head:
AEM Adj Cam Gear
ARP Head Studs
Stock Valves
Drivetrain:
Stock Y8 Tranny
Stock Axels
Fuel and Tuning:
Hondata S200
Turbo Setup:
Lovefab Downpipe
Tial 38mm Wastegate
Tial BOV
SVE 3bar Map Sensor
Re: New 1/4 mile times for my turbo D16 (pgmatt)
Nice times bro!
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by pgmatt »</TD></TR><TR><TD CLASS="quote">Nice 60foot.The setup looks clean too How much boost were you running?</TD></TR></TABLE>
His sig says 14psi.
His sig says 14psi.
Location: Destroying turbo ITR motors in Minneapolis, MN, U.S.A.
Nice numbers man!!!
I can't wait to see what that little SC50 does on the GSaaaRRRR
Re: New 1/4 mile times for my turbo D16 (eh3 93)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by eh3 93 »</TD></TR><TR><TD CLASS="quote">When are you going to turn up the boost? </TD></TR></TABLE>
Hopefully soon. I have alot of other things taking up time/money right now so we'll see.
Re: New 1/4 mile times for my turbo D16 (platinum00)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by platinum00 »</TD></TR><TR><TD CLASS="quote">looks good Ryan. how many times have you bene out with the slicks?
platinum.</TD></TR></TABLE>
This was my third time out on them.
Re: New 1/4 mile times for my turbo D16 (boostincoupe)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by boostincoupe »</TD></TR><TR><TD CLASS="quote">Nice numbers man!!!
I can't wait to see what that little SC50 does on the GSaaaRRRR </TD></TR></TABLE>
Well hurry up and get on it then! I want to see too.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by gitwidit »</TD></TR><TR><TD CLASS="quote">Nice work Ryan
Now turn up the boost! </TD></TR></TABLE>
Theres a few other things to do first.
Re: New 1/4 mile times for my turbo D16 (young noob)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by young noob »</TD></TR><TR><TD CLASS="quote">what rpm do you shift at?</TD></TR></TABLE>
Right about 8000 on the stock tach. I accidently shifted out of second early on that run though.
Launch is at 7K.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Cobra Tim »</TD></TR><TR><TD CLASS="quote">Too bad Alens mustangs fuel pump took a **** </TD></TR></TABLE>
Which Mustang was that? There were alot of them.
Launch is at 7K.
