Searched: Quick Answer. Oil Pressure #s
Hi Guys,
Just curious if anyone out there is running a low compression LS/Vtec boosted application and what oil pressure you're seeing while cruising? If you could name speed and rpm that'd be great.
I'm asking because I find (currently only on 3psi but upgrading soon) and not putting my foot into the gas I'm at 50psi. Is this normal? low? high?
-Rik
-Rik
Re: Searched: Quick Answer. Oil Pressure #s (Rikter)
i think my cruising is 60psi 25mph or 50
when i go wot its a little higher
i will let you know next time i take my car for a spin
Re: Searched: Quick Answer. Oil Pressure #s (jdm'dc2sc61)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jdm’dc2sc61 »</TD></TR><TR><TD CLASS="quote">hmm i think somethings wrong with my sender because i see 50 psi at start-up, idle, and cruising lol. </TD></TR></TABLE>
at startup the oil pressure will be very high mine is around 80+psi because of the cold oil, but once its warmed up it should drop
Re: Searched: Quick Answer. Oil Pressure #s (Soccerking3000)
the colder your oil is the higher the pressure will be. i see 80-90PSI during cold start @idle and 16-18psi once warm.
platinum.
platinum.
