boost spikes
Old Aug 10, 2006 | 06:51 PM
jdmfr3ak's Avatar
Default boost spikes
i have the drag kit. the turbonetics wastegate and the apexi boost controller would not hold boost at a certain psi. wat could that be. help
Old Aug 10, 2006 | 07:16 PM
siblues's Avatar
Default Re: boost spikes (jdmfr3ak)
That manifold and wastegate combo is known to do that because of the small size of the wastegate and the wastegate placement.
Old Aug 10, 2006 | 07:59 PM
boostedcivicsir's Avatar
Mr. Badwrench
my deltagate held great under 10 psi.
added a 38mm tial and it held 17 psi no issues.
Old Aug 10, 2006 | 08:04 PM
jdmfr3ak's Avatar
Default Re: boost spikes (siblues)
so ur sayin that i should go for a bigger and different brand of WG. which one should i go for. im want to boost 20 psi
that **** holds no boost at all do u think that it might be the controller. OR than again its the wg.
Old Aug 10, 2006 | 08:09 PM
Mr. Badwrench
what size downpipe?
i think you may have another issue.
like i said, i had no issues with my 38mm tial and stock downpipe.
Old Aug 10, 2006 | 08:36 PM
94ex-vtec
Guest
Posts: n/a
kind of interesting you say that about the downpipe. I just went from my gay little 2.25" downpipe to a 3". I am using an internally gated Garret T3 super 60, and a Hallman ES manual boost controller. Before i had the downpipe upgraded to a 3", the boost held rock solid, now it spikes about 1-2 psi.
Old Aug 10, 2006 | 08:40 PM
Mr. Badwrench
Default Re: (94ex-vtec)
the problem is the placement of the gate on the drag manifold. it pulls exh off of one runner only, and a 3" dp exploits that even more.
Old Aug 11, 2006 | 05:05 AM
jdmfr3ak's Avatar
i have 2.25 dp
Eklsv-t
Apr 6, 2008 08:08 PM
Synapse
May 1, 2007 08:42 AM
whoneedzvtec
Oct 21, 2005 07:57 PM
Racer X
Mar 27, 2003 01:07 PM
