help me figure out how to make my downpipe!
help me figure out how to make my downpipe! ***problem solved....pics****
i just got my gt3076r in today and it seems like im gonna have a problem making a downpipe. the discharge flange is a 4 bolt 2.5" and i want to run a 3" downpipe and exhaust, so i think im gonna have to start the downpipe with 2.5" tubing then expand to 3" right before the oilpan. my other problem is that the radiator is in the way. i only have about 3.5" to make a 90 turndown out of piecuts or something, or i could use a 45 to run the downpipe behind the radiator and then 90 down. i posted some pics to explain the placement. can you guys post some pics of how you ran your downpipes with a similar setup or give some suggestions on what i should do? thanks
Modified by civicskater at 11:45 PM 8/11/2006
Re: help me figure out how to make my downpipe! (civicskater)
Of course the first question is can you turn it around. In my case I could be an air filter would not fit, and I wanted to use one so I ran it like you have it. I just had to move **** around.
hah check my second post......ive seen your build thread....i referred to it a lot during my build, but id like to keep my rad in the stock spot
yeah the rad can move over about 1/2 inch and i plan on doing that
im thinkin that im just gonna have to make a bunch of pie cuts to run the first 90 down
i had the same problem man, i had to get an adapter made to go from 2.5 to 3 inch right off the turbo.... works fine now, i bought a slim fan and cleared the rad by about an inch...
my house has wheels on it
Re: (Topdawgg)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Topdawgg »</TD></TR><TR><TD CLASS="quote">i had the same problem man, i had to get an adapter made to go from 2.5 to 3 inch right off the turbo.... works fine now, i bought a slim fan and cleared the rad by about an inch...</TD></TR></TABLE>i think there is a dirt dobber nest on your wastegate feed pipe....
here is mine
there is probably less tahn an 1/8" clearance between it and fluidyne radiator....but 1/8" is better than nothing
here is mine
Re: (BrokeAssWhiteboy)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BrokeAssWhiteboy »</TD></TR><TR><TD CLASS="quote">i think there is a dirt dobber nest on your wastegate feed pipe....
yea i know, and thats why im gettin mad boost creep, my wastegate isnt opening at all
thanks for all the input guys
i cant put the compressor on the passenger side because its tooo big and i would have to shave wayyyyyy too much off the block
either make a custom mount for your radiator or buy a 3" vband clamp kit and weld that straight onto the exhaust housing, then make som pie cuts and make it how ti needs to be, using a flange is going to be hard with that kind of bend becuase you will never get all the bolts in plus vband is really nice and easy to remove and put on and it looks nice,
Re: help me figure out how to make my downpipe! (abnaasefmb)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by abnaasefmb »</TD></TR><TR><TD CLASS="quote">
i was thinking about hooking up the coolant line for turbo off that bolt like you have. how's it working for you?
well i think ive got it figured out.
i used about 3 pie cuts then ill run the 90. it was actually a lot easier than i thought. the only bad part was making the pie cuts fit because all ive got to cut with is an angle grinder with a cutoff wheel. ill post some pics after i get it tacked up, its just duct taped together right now
Re: help me figure out how to make my downpipe! (mahcivic)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mahcivic »</TD></TR><TR><TD CLASS="quote">either make a custom mount for your radiator or buy a 3" vband clamp kit and weld that straight onto the exhaust housing, then make som pie cuts and make it how ti needs to be, using a flange is going to be hard with that kind of bend becuase you will never get all the bolts in plus vband is really nice and easy to remove and put on and it looks nice,</TD></TR></TABLE>
that's a pretty good idea.
Re: (enigma94)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by enigma94 »</TD></TR><TR><TD CLASS="quote">cuver it hard back toward the block the ounce its cleared the radiator curver it downwards and you're set.</TD></TR></TABLE>
thats basically what i did, i used 3 pie cuts to cut it back towards the block on a 45ish degree angle then used a mandrel 90 to turn it down towards the oil pan. ill have some pics up later today of the progress
Re: help me figure out how to make my downpipe! (project dc2)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by project dc2 »</TD></TR><TR><TD CLASS="quote">its not that hard ... if you want you can buy a downpipe from me . </TD></TR></TABLE>
or buy mine which was made him
