Turbos Interchangable Without Changing Piping? TURBO BLOWN
I want a CRX tattoed on my butt
So my junkyard turbo gave way on me this week, shes seeping oil out the hot side and im burning oil out of my exhaust. Cant take it anymore
Needs to be replaced
The turbo is a t3 .60/.63, garrett with a 5 bolt flange
I personally want to spend very little on the replacment turbo (SSAUTO) but they dont sell .60/.63's obviously. I probably even want to step down a size as this thing is kinda of unusable and I dont like the powerband.
Is it possible to buy another turbo and have my downpipe, dump (runs soooo close to the dp!) etc all change over
Or will I have to redo everything?
My downpipe was litteraly made to run about 1/4" away from my oil pan so that pretty much cant move.
Need to know what sizes will work
Thanks
Thanks
Re: Turbos Interchangable Without Changing Piping? TURBO BLOWN (PINKS)
the whole reason you're in this situation is because you didn't spend the time and money getting a good quality good condition turbo. so why go through the same thing all over again?
imagine how happy you would be if you changed your manifold and downpipe to fit an ssac turbo and then found out it only lasts for a week and blows the seals out.
Re: Turbos Interchangable Without Changing Piping? TURBO BLOWN (Turbo Dan)
We have an SSAC turbo that blew oil out the seals after 4 months. We were curious to see how long it would last, but did expect it to go. It was only $100 and lasted 4 months, so not too big of a waste of money.
Re: Turbos Interchangable Without Changing Piping? TURBO BLOWN (jeremydde)
I just dealt with a guy who did the same thing. T3 turbo got it for free, blew the seals on it TWICE now, he just refuses to buy a new one. Funny thing is, he's rebuilt it enough times now for various reasons to make that turbo more expensive than buying a new one and having it run flawlessly. Then again, he also has an HF manifold with the adapter plate held on by, get this, lug nuts.
Your best bet will be a T3 .48 A/R 5 bolt. My suggestion would be to buy it new, that way, you won't be spending so much money replacing your turbo every few months.
Re: Turbos Interchangable Without Changing Piping? TURBO BLOWN (CoreyR)
Re: (pane93civhb)
Your downpipe should bolt right up. All t3 5 bolt housings are the same and should bolt right up without a problem. Good luck with that turbo, your probably gonna need it
Re: (delslo93)
I dont give a expletive how long it lasts, my .60.63 is getting rebuilt the day it comes off, have it back in my hands in two weeks
fastcivicboy
02-09-2006 09:22 PM
sporkcrx
11-03-2002 11:33 AM
