Profec Spec II - Spooling Faster - Do you need to retune >>
I have a profec Spec II, and was going to start messing around with the "start boost" setting which will increase my spool time a little bit. Its currently set at "0" so im sure i can get a little bit better spool time.
Anyway. If I do mange to get better spool time, do I need to retune the motor. Im not quite sure how fuel tables and timing are calculated during boost.
Thanks guys,
platinum.
Thanks guys,
platinum.
Re: Profec Spec II - Spooling Faster - Do you need to retune >> (platinum00)
anything that affects the air flow characteristics of a motor, requires a retune
a retune doesnt nesesary means the whole powerband, but the areas affected
i guess i will leave the setting alone until i go back to the dyno.
anyone have experience with how much sooner spool is noticed using this?
platinum.
platinum.
It can be quite a bit difference in responce. If I crank the gain on the original Profec B, I can get spool at least 500rpm sooner. However, I find boost to be very unstable once it reaches the desired boost level.
Moderator
Re: (ELSpool)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ELSpool »</TD></TR><TR><TD CLASS="quote">It can be quite a bit difference in responce. If I crank the gain on the original Profec B, I can get spool at least 500rpm sooner. However, I find boost to be very unstable once it reaches the desired boost level.</TD></TR></TABLE>
that's if the SET GAIN is out of proporton with the actual GAIN on the Profec B Spec II.
Re: (TheShodan)
500rpm sooner. wow, that more then i thought.
i could get a BB turbo and play with this setting and gain 500-1000 rpm sooner spool.
huh, and i always wonder were my money goes
platinum.
platinum.
B16Civic93
07-13-2005 02:12 PM
