which cam to use?
I am almost done my rebuild engine for my 85 prelude drag car.
my spec is:
b20 block
eagle H beam rod
wiseco 11.3 cr piston
G/E guard
ARP H/S
stock b16 head
and i am going to feed 180 shot of nos.
so , my Q is, if i want to upgrad my cams, which type i have to go with? N/A cams or turbo cam?
thanks in advance.
my spec is:
b20 block
eagle H beam rod
G/E guard
ARP H/S
stock b16 head
thanks in advance.
B A N N E D
From: Orange County / Palm Springs 714/76hoe, ca, usa
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BoostedEG6 »</TD></TR><TR><TD CLASS="quote">stock type R cams
I have 2 set hit me up on my email or aim check my sig down there<VV
</TD></TR></TABLE>I have 2 set hit me up on my email or aim check my sig down there<VV
depends on the manifold u are going to use. if you are using a log manifold use a cam with a short duration if you are going to use equal length then do an all motor cams. if know your set up and wat you are going to use then you can 100% of the time find a cam thats gonna work better than a stock one just my 2 cents
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by bigbadboy »</TD></TR><TR><TD CLASS="quote">depends on the manifold u are going to use. if you are using a log manifold use a cam with a short duration if you are going to use equal length then do an all motor cams. if know your set up and wat you are going to use then you can 100% of the time find a cam thats gonna work better than a stock one just my 2 cents
It has been proven many of times that a stock type r cam will make just as much if not more than any aftermarket turbo cam.
</TD></TR></TABLE>It has been proven many of times that a stock type r cam will make just as much if not more than any aftermarket turbo cam.
i am not going to turbo charge my engine, i am going to feed nitros on it.
</TD></TR></TABLE>i am not going to turbo charge my engine, i am going to feed nitros on it.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by abnaasefmb »</TD></TR><TR><TD CLASS="quote">how much is gas over there? and what octain do you have?</TD></TR></TABLE>
My car is drag car, and i can't use it on the street ( see my sig).
i am going to use vp 103 or c12 mix it with 89 pump gas, i have P&H 440cc injectors from 7mgte and engine manegmant will controlled by chiped PR3 with BRE.
