what does it mean when the upper radiator hose is squeezed in when the engine is cold?
Old Aug 13, 2006 | 09:16 PM
djay86's Avatar
Default what does it mean when the upper radiator hose is squeezed in when the engine is cold?
as the topic title states..
im running a b18a, homemadeturbo setup, koyo half size aluminum radiator.
could the problem be my cheap .9 bar cap?
i changed the thermostat about 5k miles ago with an oem unit.
any help is appreciated, tia
Old Aug 13, 2006 | 10:00 PM
MassScene's Avatar
Default Re: what does it mean when the upper radiator hose is squeezed in when the engine is cold? (djay86)
sounds like there is air in the system
Old Aug 13, 2006 | 10:10 PM
djay86's Avatar
Default Re: what does it mean when the upper radiator hose is squeezed in when the engine is cold? (MassScen
whats the best way to get it out? run the car with the rad cap off and undo the bleeder screw on the head?
Old Aug 13, 2006 | 10:28 PM
CoreyR's Avatar
i run the car without the cap on to bleed my system.
Old Aug 13, 2006 | 10:46 PM
djay86's Avatar
does the heat have to be on?
Old Aug 13, 2006 | 11:05 PM
Oleg's Avatar
Dude, on all the cars that means one thing - old radiator hose. Get a new one from NAPA.
Old Aug 14, 2006 | 04:57 AM
MassScene's Avatar
leave radiator cap off. it wont hurt to leave the heat on i dont think. once the bottom radiator hose is hot and the thermostat is open you gently squeas the hose to get the air to bubble out of the top. the radiator fluid should be getting low no. add fluid every time it gets low. repeat till no more air is in there.
Old Aug 14, 2006 | 05:55 AM
boostedcivicsir's Avatar
Mr. Badwrench
Default Re: what does it mean when the upper radiator hose is squeezed in when the engine is cold? (Oleg)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Oleg &raquo;</TD></TR><TR><TD CLASS="quote">Dude, on all the cars that means one thing - old radiator hose. Get a new one from NAPA.</TD></TR></TABLE>
thats what i was thinking.....
and when bleed hondas, i put the front on jack stands, and run with the cap off, heat on till the fan cycles.
Old Aug 14, 2006 | 06:53 AM
young noob's Avatar
Default Re: what does it mean when the upper radiator hose is squeezed in when the engine is cold? (boostedc
get a new hose, add coolant, then run the car with the cap off at 3000 rpms till the thermostat opens, squeeze radiator hose to push coolant into the water jackets and all that good stuff, add coolant as needed, then add into coolant resovoir to max line on the resevoir
Old Aug 14, 2006 | 07:53 AM
Finland's Avatar
It means either:
A. bad radiator cap. (not allowing coolant to be pulled from your over flow bottle when the engine cools down.
B. blockage in the hose between your over flow bottle and the nipple on your radiator fill neck.
Old Aug 14, 2006 | 08:05 PM
b16adx's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by MassScene &raquo;</TD></TR><TR><TD CLASS="quote">leave radiator cap off. it wont hurt to leave the heat on i dont think. once the bottom radiator hose is hot and the thermostat is open you gently squeas the hose to get the air to bubble out of the top. the radiator fluid should be getting low no. add fluid every time it gets low. repeat till no more air is in there. </TD></TR></TABLE>
whenever i try that method my coolant starts to come out...what am i doing wrong
Old Aug 14, 2006 | 08:51 PM
Zakar's Avatar
once filled you bleed the system with the cap ON.. you do need the front in the air.. (jackstands or big hill)
Old Aug 14, 2006 | 09:49 PM
Jaker's Avatar
Default Re: (Zakar)
Honda intended the cooling system to be bled as follows:
Open bleed screw
Open heat control (full heat inside car)
Fill radiator until bleed screw flows coolant alone (no air/bubbles)
Close bleed screw
Put on radiator cap
Fill overflow bottle to "max" level
Run engine to operating temperature
That's it, you're done.
Now when the engine cools 100%, if there are any air pockets in the cooling system, they will purge themselves and the coolant in the overflow bottle will be drawn into the cooling system to take the place of the air. If you do this without having the heat turned on inside the car, chances are you'll have some rather large air pockets in the heater core, and they have a much more difficult time purging themselves out.
Old Aug 14, 2006 | 10:20 PM
bigbadboy's Avatar
wat if you have no heater to turn on???
Christopherian1982
17
May 17, 2008 12:04 PM
slywfbpsi
Acura TL, RL & ZDX
Jun 6, 2004 05:44 AM
pnltnc
Mar 30, 2004 06:30 PM
oMek
Feb 4, 2004 06:55 PM
TenaciousC
Aug 22, 2002 02:11 PM
