oil feed source
Old Aug 9, 2006 | 06:28 PM
teddy_dc2's Avatar
Default oil feed source
is the hole (below screw driver) a good oil feed source? i used the oil pressure sender in the back, it's in a tight space and always moist with oil.
Old Aug 9, 2006 | 06:30 PM
1baddcivicsi's Avatar
Default Re: oil feed source (teddy_dc2)
personally i just got done having my oil pan welded with a fitting and ran a hose up to the turbo. that is what i would do
Got_soy's Avatar
i think it only get oil when v-tachk engages
Old Aug 9, 2006 | 06:33 PM
Got_soy's Avatar
Default Re: oil feed source (1baddcivicsi)
oil feed, not drain
Old Aug 9, 2006 | 06:34 PM
BoostedEG6's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 1baddcivicsi &raquo;</TD></TR><TR><TD CLASS="quote">personally i just got done having my oil pan welded with a fitting and ran a hose up to the turbo. that is what i would do</TD></TR></TABLE>
I hope your talking about your drain
Old Aug 9, 2006 | 06:35 PM
Default Re: oil feed source (BoostedEG6)
of course
boostedcivicsir's Avatar
Mr. Badwrench
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by teddy_dc2 &raquo;</TD></TR><TR><TD CLASS="quote">is the hole (below screw driver) a good oil feed source? i used the oil pressure sender in the back, it's in a tight space and always moist with oil.</TD></TR></TABLE>
if you want your turbo to only get oil in vtec.
Old Aug 9, 2006 | 07:08 PM
teddy_dc2's Avatar
Default Re: oil feed source (boostedcivicsir)
just wondering
Old Aug 9, 2006 | 07:13 PM
Mr. Badwrench
alls i know is a friend did that on his h22 and it ate the turbo up because no oil out of vtec.
Old Aug 9, 2006 | 07:22 PM
TypeSLO's Avatar
not to mention you may lose some oil volume which you need over the valvetrain.
Old Aug 9, 2006 | 07:26 PM
unusual71's Avatar
dont most people T it off a line for the input and for the return they go to the oil pan?
Old Aug 9, 2006 | 08:12 PM
TypeSLO's Avatar
Default Re: (unusual71)
t at the back of the block
Old Aug 9, 2006 | 08:21 PM
Tactic$'s Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by teddy_dc2 &raquo;</TD></TR><TR><TD CLASS="quote">just wondering
You don't believe everything you read do you?
Old Aug 9, 2006 | 08:51 PM
planeman01's Avatar
get a sandwich adaptor from golden eagle
Old Aug 10, 2006 | 04:10 AM
teddy_dc2's Avatar
Default Re: oil feed source (Tactic$)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Tactic$ &raquo;</TD></TR><TR><TD CLASS="quote">
You don't believe everything you read do you? </TD></TR></TABLE>
no just wondering if it would work cause it would make life a lot easier
Old Aug 10, 2006 | 04:22 AM
Autoworks's Avatar
Get a sandwich plate, it's as easy as it gets
Old Aug 10, 2006 | 06:11 AM
Topdawgg's Avatar
dont tap to the front of ur head.... like someone said... its robbin oil from the valvetrain.... and its not a good solid source...
back of the block takes 10 minutes... its simple... even simpler if you dont have an oil pressure gauge to install.. just run it into the oil light hole
97grnrs
Nov 21, 2006 10:35 AM
D16y8_619
Sep 8, 2006 09:05 PM
SM00TH976
May 17, 2006 08:59 AM
moesrex
Apr 3, 2006 07:35 PM
jdm-ray
Jul 2, 2005 09:29 PM
