what else can i do to fix an oil pan leak
ok i have tried numerous new gaskets and some black silicon stuff and nothing is working. this is a rank leak. what can i do?
Re: (SOHCD16y8)
I have an aftermarket pan from Canton, not really for a D series, but i kept trying to seal it up with silicone.... kept leaking, ended up using a stock gasket, and tighteded that sucker down.
If yours is all stock, assuming that its level, make sure you start from the middle and go out evenly, i think they recommend criss crossing. Also, they don't need to be super tight, more uniform then anything.
You could also explain a little more about your leak and setup.
Re: what else can i do to fix an oil pan leak (the.hamburglar)
I had a friend who had this problem, his turned out to be a warped pan i believe. But his was wierd, it would like blow the gasket out, like there was alot of pressure in there.
Re: (btech)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by btech »</TD></TR><TR><TD CLASS="quote">clean the area from all oil and greese residue.... then jb weld that sht shut.</TD></TR></TABLE>
hahaha
hahaha
trooper0641
14
10-11-2005 07:11 PM
