turbo waste-gate question?????
on top of the waste-gate theres a place where a vaccum in goes and on the side, what lines need to be ran to these? also on the side of the turbo there is a gold bolt that needs to be taken out and a line installed, but what?
Re: turbo waste-gate question????? (1baddcivicsi)
The top port on the wastegate is for utilizing an electronic boost controller only. The side port is a boost pressure source that needs to be hooked up to somewhere that sees vac and boost, like the intake manifold, or you can hook it up to the port on the turbo that you mentioned. This is also the port you use when using an MBC.
This has been cover many many times, search around if you need more help there will be plenty of info and some diagrams you can follow.
DaYZeD.1
03-28-2008 06:54 AM
GOIN V8 HUNTIN
12-12-2006 05:17 PM
