Is this going to be a problem? NEED HELP.
Old Aug 9, 2006 | 07:41 PM
Type-ARR's Avatar
Default Is this going to be a problem? NEED HELP.
There is a crack coming from the stud hole on the intake side of one of my B series heads. I need to know what you guys think I should do if anything. . .
Old Aug 9, 2006 | 11:28 PM
Type-ARR's Avatar
anyone
Old Aug 9, 2006 | 11:31 PM
whoneedzvtec's Avatar
Default Re: Is this going to be a problem? NEED HELP. (Type-ARR)
i cant see how far back the crack goes but i would say its usable. just dont tighten that bolt down too much. also u are gonna run the risk of that crack getting larger over time. good luck.
Old Aug 9, 2006 | 11:48 PM
playahwitgame's Avatar
Default Re: Is this going to be a problem? NEED HELP. (whoneedzvtec)
its ghetto, but what u can do after you put it on is put a layer of jb weld for extra support. ghetto, but probably will give it the extera strength it may need.
Old Aug 10, 2006 | 06:20 AM
Topdawgg's Avatar
that crack should be fine... im even missing the bolt on mine on the edge and i have no problems... you can leave it out, just make sure the rest are tight...
and i was confused when u said B series HEADS?
skateboard c
May 27, 2008 08:37 PM
krazym
Jan 6, 2008 09:45 AM
Type-ARR
Aug 9, 2006 09:41 PM
eric8876
Apr 25, 2004 06:36 PM
Big Business
Jan 28, 2003 07:35 AM
