just fucking great, ITR motor siezed, not I need your help w/ a rebuild...
just ******* great, ITR motor siezed, not I need your help w/ a rebuild...
alrigth the headgasket blew and idk what happened the coolant got intot he cyllinders or whatever and siezed up the whole bottom end on my low boost ITR swap. I need you guys help, I need to rebuild the bottom end, with boost in mind obviously. I'm having my friends garage do it for me, btu I don't know all the components I need. Canyouplease help me out and list them out for me, asap please. THANKS!
I'm kinda ignorant to thsi part of the motor, I wanna' make like 350 whp tops as a dd, so what parts do I need to fully go about with this so I can order them. (pistons, rods, rings, ????)
Re: just ******* great, ITR motor siezed, not I need your help w/ a rebuild... (Naudlee)
I would check first if you cracked a sleeve.You may be needing a new block.Anyways hit up the sponsors section for rod and piston combos.
read andy's writeup for his engine build:
part 1: https://honda-tech.com/zerothread?id=765604
Part 2:
https://honda-tech.com/zerothread?id=773739
hope this helps!
Part 2:
hope this helps!
Re: (kynetik)
Tear apart the block first. Inspect everything before jumping the gun on ordering stuff. But in situations like this, bottom end is toast.
Pistons, Rods, Bearings etc. (shameless plug https://honda-tech.com/zerothread/1464232)
May also consider new gasket, headstuds also
Just take it apart first, let someone correctly inspect it all before getting a bunch of parts you may not need
I was planning on beefing up the internals this winter anyways, he told me the whole bottom end is siezed, he cant even manually crank it. WHats your deals on complete re-build kits with boost in mind, ITR is highc ompression I know I want something lower so it'll be safer and better for boost, PM me a shipped price, I'm looking to order asap. Thanks!
Re: (Naudlee)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Naudlee »</TD></TR><TR><TD CLASS="quote">I was planning on beefing up the internals this winter anyways, he told me the whole bottom end is siezed, he cant even manually crank it. WHats your deals on complete re-build kits with boost in mind, ITR is highc ompression I know I want something lower so it'll be safer and better for boost, PM me a shipped price, I'm looking to order asap. Thanks!</TD></TR></TABLE>
Do you want him to come to your house and pull your motor too?
*******, I'm kinda not educated when it comes to the internals of a motor, Iknow what the parts do and what they look like but I don't know which compression ratio to get and which bore size? Cans omeone give me a good round of advice...hybrid-performance what do you recommend?
Re: (Naudlee)
Question you have to ask is,
Doyou want to sleeve it?
Which Bore? Prob 83mm to be safe if you sleeve, if not 81.5mm to clean up the existing bore.
Pistions? CP, Wiseco etc.
Rods? Manley, Pauter, Crower etc.
Compression? 9.0-9.5:1 is good
Bearings? OEM if you can, if not ACL's are sufficient with the proper clearances
Headstuds? ARP
New Oil Pump, Water Pump, Headgasket of proper bore.
Headstuds? ARP
Re: (96 GSR-T)
when my ITR motor seized, i bought another complete block... and built that up...
you can rebuild yours but i'd suggest you get a new crank and all new bearings... if you're on a budget just get some eagle rods and some type of forged pistons...
oh and a new oil pump while you're at it
I was looking at hybrid-performance.com liek above... and I can get nice CP pistons, eagle rods, and acl bearings for $840 shipped any size/compression ratio I wan't. What else would I need to purchase. Please guide me in the right direction... THANKS
Re: (Naudlee)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Naudlee »</TD></TR><TR><TD CLASS="quote"> Enlighten me please...</TD></TR></TABLE>
there is a button for that
its in the top right SEARCH lol
on a serious note....
if your goals are around 350 whp
then a basic CP piston and eagle combo will work
again u will need to see what is really up with the bottom end and what u need
so take it apart
does it need a waster pump, oil pump, thrust washers, timing belt, headgasket bearings blah blah? pretty much what 96 GSR-T said
so take it apart
ALRIGHT: Ijust get a phonecall from my friend, he has a friend who's offered to trade his perfect working order 94 GSR motor for my blown one, motor for motor. I don't know the mileage on it yet, but he says its mint. What do you think? Iknow GSR is safer with boost. TOo good a deal to pass up?
Modified by Naudlee at 9:33 PM 8/11/2006
LSD will be kept, just motor for motor. Also, will I have to make any modification to the charge piping/downpipe for it to fit like it did on the ITR motor in there or will I be all set?
aight, keeping throttle body and intake man, jw if what about wiring, my cars obd2 and I know the motor is a 98 ITR aswell, the gsr is a 94, anything to worry about? Already ran a jumper harness to run a p28 ecu, as far as intheengine bay,all wires/plugs be the same?
Re: (Naudlee)
you cant use the ITR intake mani on the GSR's.USe the engine harness thats on ur ITR and it will all line up, except for the dual butterflies in the GSR intake mani.U will have to wire them urself.
