thinking about a valvetrain. lsvtec on about 15psi?? not sure of what to get
did some searching and im still unsure.
setup will be an lsvtec, b16 head. gsr cams to start, nothing more than itr cams in the future. i plan on keeping the rev limit around 8500 (currently at 8200).
i will be running between 15-18 psi, or somewhere in the low 400whp range with the 60-1 i have.
whats a good route to go? stock valves with aftermarket springs and retainers??
also what about keepers? i was reading up on them and was getting the idea that they should be steel not aluminum
Re: thinking about a valvetrain. lsvtec on about 15psi?? not sure of what to get (iBrandon)
does a supertech valvetrain come with retainer specific keepers?
also, i kinda plan on using stock valves still
Re: thinking about a valvetrain. lsvtec on about 15psi?? not sure of what to get (blackeg)
I am running supertech springs and retainers with stock valves and stock keepers and I haven’t had any problems
Re: thinking about a valvetrain. lsvtec on about 15psi?? not sure of what to get (BoostedEG6)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BoostedEG6 »</TD></TR><TR><TD CLASS="quote">I am running supertech springs and retainers with stock valves and stock keepers and I haven’t had any problems</TD></TR></TABLE>
mine has seen 9500
built gsr. with a 60-1 only on 15 lbs right now
mine has seen 9500
Re: thinking about a valvetrain. lsvtec on about 15psi?? not sure of what to get (adictionbass)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by adictionbass »</TD></TR><TR><TD CLASS="quote">
built gsr. with a 60-1 only on 15 lbs right now </TD></TR></TABLE>
good to hear. almost the same as me, but i have an lsvtec.
is the seat pressure on these springs too much to run oe gsr cams with???
a few years ago i had skunk springs in a z6 with oem cam and i believe it eventually caused me to shear the locking key off the camgear
nope, ive had both stock b16s and stock gsr cams running with them
Well if your going to keep relativley stock redline then you should stick with the GSR cams. You can also run GSR cams to 8500 on a single spring setup. Supertech is a great spring setup and would be nice for the ITR or gsr revving higher or just for insurance.
Stock keepers shouldnt be an issue, im running stock keepers on crower dual springs, all motor cams and ferrea valves to 8500 on an LS and there fine
same here
same here
Im running supertech dual valve springs and retainers with Ferrea valves on my ls/vtec set up and im loving them im only at 8 pounds for the break in.
mitsuman
12-18-2007 03:41 PM
DC2 Mang
07-17-2006 03:08 PM
turbotime
04-05-2006 02:03 PM
