200whp+ possible with d16z6 and 8.5psi?
I was just wondering if it would be possible on 8.5psi I have a 50trim t3/t04e+headwork+59300 cam+skunk2 IM and TB+ good tune.
Re: 200whp+ possible with d16z6 and 8.5psi? (wfocrx)
What exactly does 8.5psi have to do with anything? Why are people always so set on running XX amount of boost? Im sure your setup is capable of producing that and then some... set a power goal and tune it, your PSI should be an end result.
IRONlung201,
8.5psi is the spring in the wastegate I have, therefore, it has everything to do with what Iam running.
94ex-vtec, I do plan on running more boost; but, not until I get everything working perfectly on 8.5psi
i ♥ snails
**** look at full races sohc build massive hp on stock sleeves with jeff evans mastermind behind the tune. 30psi stock sleeves somewhere around 400-500hp i cant remember. Props too them
jarven93
12-12-2006 02:09 PM
