What is this hole in turbo for?
Re: (undercoverdc2)
I would actually plug that connection and use a vacuum source at the intake manifold, the Compressor housing doesn't show you accurate pressure because once it passes the IC, you have a pressure drop.
Re: (nebulight)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by nebulight »</TD></TR><TR><TD CLASS="quote">I would actually plug that connection and use a vacuum source at the intake manifold, the Compressor housing doesn't show you accurate pressure because once it passes the IC, you have a pressure drop.</TD></TR></TABLE>
Run your vacuum off the compressor housing... thats what it is there for. You get more immediate response to the WG. Shorter lines are always better. If you feel that you are dropping too much boost because of your IC/Piping... use a boost controller to regain that boost.
Location: Destroying turbo ITR motors in Minneapolis, MN, U.S.A.
Re: (HybridKOOP)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by HybridKOOP »</TD></TR><TR><TD CLASS="quote">It's an oil-feed </TD></TR></TABLE>
Oil return, champ.
Oil return, champ.
Re: (Hybrid_Coupe)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Hybrid_Coupe »</TD></TR><TR><TD CLASS="quote">no that hole doesnt pull vacuum, its only boost reference so you cant run a blow off valve off of that.</TD></TR></TABLE>
I don't want to run blow off from it. I'm asking if I can run WASTE GATE from it..
Mr. Badwrench
Re: (splitime)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by splitime »</TD></TR><TR><TD CLASS="quote">
Run your vacuum off the compressor housing... thats what it is there for. You get more immediate response to the WG. Shorter lines are always better. If you feel that you are dropping too much boost because of your IC/Piping... use a boost controller to regain that boost.</TD></TR></TABLE>
i always run mine from there, yes you have a 2 psi drop, but you can make that up. it is more consistant to run that way. imho.
InTeGrA B18b1
06-21-2003 02:34 PM
